21
As of now I don't have a wifi adapter for Raspberry Pi with me. If I want to update or install any software, my Rpi should be connected to internet. Is there any way I can install software in offline mode? Is there any source where I can find software packages such as Omxplayer etc., do download from my other PC (where I have internet access) and install it on the Raspberry Pi?
Any help would be greatly appreciated.
nbsrujan
  • 577
Assuming you're using Raspbian, you need to find out which .deb file you need, and transfer those to your Raspberry Pi, and place them in /var/cache/apt/archives/partial, and then just use the command:
sudo dpkg -i /var/cache/apt/archives/partial/xxxx
where xxxx is the exact name of the .deb file you want to install
If you need to find dependencies, http://www.debian.org/distrib/packages will help.
Also the Raspbian repositories are located here http://archive.raspbian.org/raspbian/pool/
That's where the plain .deb files will be for the Pi.
0xC0000022L
  • 192
Lawrence
  • 2,692
To install programs on machine unable to access internet
enter command as normal and read output look towards end of results for the failed to fetch lines and enter these links into a web capable machine, save the links to a usb memory stick. Repeat for all failed to fetch lines
*pi@raspberrypi ~/pi $ sudo apt-get install scrot
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  giblib1
**Failed to fetch** http://mirrordirector.raspbian.org/raspbian/pool/main/g/giblib/giblib1_1.2.4-8_armhf.deb*
insert the usb drive you downloaded these files onto and navigate to them (easiest using startx file explorer program) in file explorer press F4 (or Tools, open current folder in terminal)
to manually install the programs in terminal enter commands bolded below. Repeat sudo dpkg -1 filename for each file downloaded.
*pi@raspberrypi /media/KINGSTON/pi install packs $ **sudo dpkg -i scrot_0.8-13_armel.deb**
Selecting previously unselected package giblib1:armhf.
(Reading database ... 85074 files and directories currently installed.)
Unpacking giblib1:armhf (from scrot_0.8-13_armel.deb) ...
Setting up giblib1:armhf (1.2.4-8) ...
pi@raspberrypi /media/KINGSTON/pi install packs $ **sudo dpkg -i scrot_0.8-13_armhf.deb**
Selecting previously unselected package scrot.
(Reading database ... 85081 files and directories currently installed.)
Unpacking scrot (from scrot_0.8-13_armhf.deb) ...
Setting up scrot (0.8-13) ...
Processing triggers for man-db ...*
program should now work.
hope this makes sense
skibulk
  • 209
P aul
  • 151
