My new pi0w isn't connecting to my home wifi in a headless environment. Here's my set up:
$ ifconfig wlan0
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:70:cb:b1 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
$ systemctl status dhcpcd
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-04-20 22:10:45 EDT; 6min ago
Process: 259 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 275 (dhcpcd)
CGroup: /system.slice/dhcpcd.service
└─275 /sbin/dhcpcd -q -b
Apr 20 22:10:48 bramble1 dhcpcd[275]: wlan0: carrier lost
Apr 20 22:10:48 bramble1 dhcpcd[275]: wlan0: deleting address fe80::bb9:396e:9a4a:cfba
Apr 20 22:10:48 bramble1 dhcpcd[275]: usb0: soliciting a DHCP lease
Apr 20 22:10:49 bramble1 dhcpcd[275]: usb0: soliciting an IPv6 router
Apr 20 22:10:53 bramble1 dhcpcd[275]: usb0: probing for an IPv4LL address
Apr 20 22:10:59 bramble1 dhcpcd[275]: usb0: using IPv4LL address 169.254.14.36
Apr 20 22:10:59 bramble1 dhcpcd[275]: usb0: adding route to 169.254.0.0/16
Apr 20 22:10:59 bramble1 dhcpcd[275]: usb0: adding default route
Apr 20 22:10:59 bramble1 dhcpcd[275]: usb0: removing route to 169.254.0.0/16
Apr 20 22:11:02 bramble1 dhcpcd[275]: usb0: no IPv6 Routers available
My /etc/wpa_supplicant/wpa_supplicant.conf looks like:
country=US
update_config=1
network={
ssid="xxxxxx"
proto=RSN
key_mgmt=WPA2-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="xxxxxx"
and my /etc/network/interfaces looks like:
auto lo
auto wlan0
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet manual
It's finding my relevant network when I run sudo id dev wlan0 scan:
BSS 30:46:9a:44:b9:38(on wlan0)
TSF: 0 usec (0d, 00:00:00)
freq: 2412
beacon interval: 100 TUs
capability: ESS Privacy ShortSlotTime (0x0411)
signal: -39.00 dBm
last seen: 0 ms ago
SSID: xxxxxxxx
Supported rates: 1.0* 2.0* 5.5 11.0 18.0 24.0 36.0 54.0
DS Parameter set: channel 1
ERP: Barker_Preamble_Mode
ERP D4.0: Barker_Preamble_Mode
RSN: * Version: 1
* Group cipher: CCMP
* Pairwise ciphers: CCMP
* Authentication suites: PSK
* Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
Extended supported rates: 6.0 9.0 12.0 48.0
WPS: * Version: 1.0
* Wi-Fi Protected Setup State: 2 (Configured)
* Selected Registrar: 0x0
* Response Type: 3 (AP)
* UUID: 3be17555-a17b-36d1-d6cb-d8633ca028e9
* Manufacturer: NETGEAR, Inc.
* Model: WNDR3400
* Model Number: WNDR3400
* Serial Number: 01
* Primary Device Type: 6-0050f204-1
* Device name: WNDR3400
* Config methods: Label, PBC
* RF Bands: 0x3
WMM: * Parameter version 1
* u-APSD
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
Any thoughts?
