Some of the images I get from the Webcam using fswebcam are not displaying properly.
Comparison:
enter image description hereenter image description here
I got these images using the following command:
I'm having the same issues with 320x240 resolution.
EDIT:
I've also tried skipping some frames before getting the picture:
And, although I am getting less malformed images I'm still getting a lot (1 every 6-7 taken)
What can I do to solve this output problem?
Pikamander2
  • 359
Gerard Rovira
  • 269
6 Answers6
I was having a similar issue as well. To get rid of those malformed images try:
sudo fswebcam -r 640x480 test.jpg -S 2
. The -S instructs it to skip a number of frames,in this case two. Hope it helps!
alien
I am onto my second camera On my first cam I had constant broken images. They are proper files but the picture is distorted.
I am now using a Logitech c270 that i got cheap of an auction site. Initially i had some color issues because i over compensated for the previous camera.
Here is my current line
 fswebcam -d /dev/video0  -S 2 -s brightness=60% -s Contrast=15%  -s Gamma=50%  -p YUYV -r 1280x720 --jpeg 80 -s Sharpness=40% -s Saturation=15%   --title "New Zealand - Wellington - Tawa"  $DIR/$filename
user10106
Found the solution! After tweaking the motion.conf file for a couple of minutes I've came to this conclusion: NEVER use higher framerates than 30 for a webcam (30fps is more than enough to work on any decent camera, so higher fps just stresses the camera beyond its limits ). In conf. file (after installing motion, type in Cli: sudo nano /etc/motion/motion.conf), set the "framerate" to 30 and "webcam_maxrate" to 30. Problem solved!
P.S.-don't use higher resolutions than 640 x 480 !
darius
@darius solution does not help at all, as it seems to be related to motion, not directly to fswebcam.
For me, using a really low framerate, and skipping frames, seems to have helped a bit (not much). Something like
Problem with images?
You must generate images into a directory example one image per second
/cam 20160729154102.jpg 29-Jul-2016 18:40 132K
20160729154202.jpg 29-Jul-2016 18:41 132K
and view the one generate other and delete the first
Ex: /cam.jpg in other directory
The image to view: /cam.jpg The directory with the images: /cam
When view the image, the same in totally downloading (cm.jpg) otherwise you view the last image in some time that is downloading and some times have an error.
**PHP script (execute with cron every minute)**
<meta http-equiv="refresh" content="60">
<?php
date_default_timezone_set("America/Argentina/Buenos_Aires" ) ;
<!--<meta http-equiv="refresh" content="60">-->
  $directory="cam";
    $dirint = dir($directory);
    while (($archivo = $dirint->read()) !== false)
      $archivos[$archivo] = $archivo;
 rsort ($archivos);
 foreach ($archivos as $archivo) {
      $e=$e+1;
      if($e>2){
         $file='cam/'.$archivo;
          unlink($file);
               if(preg_match('/jpg/',$archivo)){
                       $r=$r+1;
                       $alto =400;
                        if($r<3){
                            $salida = '<img src="'.$file.'">';
                               $newfile='cam.jpg';
                               if (!copy($file, $newfile)) {
                                echo "failed to copy<br>";
                               if (!copy($file,'capturas/'. $archivo)) {
    $dirint->close();
    <div align="center">
    echo $salida;
    </div>
see the sample running: http://diarionecochea.mobi/camarita/camara.html
NULL
  • 2,240
  • 28
  • 49
Luis
I was getting only a dark picture (no detail at all) when I ran fswebcam image.jpg. However, I got a good picture when I ran
as suggested by Alexandre Strube in the answers. Thank you.
