-My problem:
I can't get autostart to work (/etc/rc.local or /etc/init.d)
/etc/rc.local screen never boots and kills the pi, which then needs to be re-flashed to work again.
/etc/init.d no auto start. Pi is still alive.
/etc/rc.local I can not ssh into the machine to delete the rc.local and holding down shift does not boot into safe mode. so I have to re-flash the .img to try again. and then fail again.
I am following goldilocks help example pifm Crash Loop my Raspberry Pi and code from http://www.icrobotics.co.uk/wiki/index.php/Turning_the_Raspberry_Pi_Into_an_FM_Transmitter#Steps_to_play_sound:
#!/bin/bash
export PATH=/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/sbin:/usr/bin
exec &>> /var/log/my_rc_local.log
cd /home/pi/pifm && ./pifm sound.wav 90.5
exit 0
I have tried deleting: export PATH=/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/sbin:/usr/bin
I have also tried different spacing with no luck
#!/bin/bash
exit 0
using a /etc/init.d/file.sh
#!/bin/bash
cd /home/pi/pifm
sudo ./pifm sound.wav 90.5
then made the script executable using
sudo chmod 755 /etc/init.d/file.sh
the test worked!!!
sudo /etc/init.d/file.sh start
then registered the script
sudo update-rc.d file.sh defaults
the pi boots/starts but the file.sh is not auto started.
any ideas?
