Some tutorials I found are outdated, but the following answer contains a collection of notes I have used to set up home, school(enterprise), & Ad-Hoc wireless connections on my Raspberry Pi 3.
Raspberry Pi 3 (kernel 4.14.30-v7+)
This post is a collection of notes and tutorials I have used for setting up wireless connections to the Raspberry Pi.
Please let me know if you experience any issues.
Headless set-up
Raspbian currently looks in the boot partition for a couple files to allow a headless set-up or connect a Raspberry Pi to a network and establish an ssh connection from an external machine without a monitor, screen or mouse.
After you load Raspbian OS onto an micro SD card, Ubuntu command:
unzip -p 2018-03-13-raspbian-stretch-lite.zip | sudo dd of=/dev/sdX bs=4M conv=fsync status=progress
Add two files to the boot partition before moving the SD card to the Pi.
- SSH must be enabled by placing a file named 'ssh', without any extension, onto the boot partition of the SD card. This will allow you to connect from an external device.
- Network connections must be defined
- add file named "wpa_supplicant.conf" in the boot partition and fill with network information following tutorial below.
Example "wpa_supplicant.conf" for home connection:
update_config=1
country=US
network={
ssid="NETWORK_NAME"
psk="password"
Now what is the Pi's IP address? Search for the MAC address, all RPi 3 have the same start to their MAC address. (Won't work on enterprise network, ask admin about privliages)
Ubuntu command:
sudo nmap -sn 192.168.1.0/24 | grep -B 2 B8:27:EB
SSH
Automatically disabled during initial boot.
Enable with
sudo raspi-config
Then select Interfacing Options → SSH → Enable
Home Network Connection
Easiest way:
sudo raspi-config
Select Network Options → Wi-fi then follow on screen instructions.
Manual way:
Edit wpa_suplicant.conf
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Add the following:
network={
ssid="NETWORK_NAME"
psk="password"
Then save the file
Enterprise Network Connection
This is how I connect to my university wifi
First create password hash and save to file (keep the single quotes around your password):
echo -n 'YOUR_REAL_PASSWORD' | iconv -t utf16le | openssl md4 > hash.txt
Then edit wpa_supplicant.conf
Add the following:
network={
ssid="NETWORK_NAME"
proto=RSN
key_mgmt=WPA-EAP
group=CCMP TKIP
identity="YOUR_USERNAME"
password=hash:5ac87xxxxxxxxxxxxxxxxxxetc
phase1="peaplabel=0"
phase2="auth=MSCHAPV2"
To add password hash:
- Move cursor to where you want to place text
- Press
ctrl+rthen insert hash.txt file- hash.txt contains (stdin)= 5ac87xxxxxxxxxxxxxxxxxxetc
- replace "(stdin)= " with "hash:"
- Save the file
Clear your bash history
history -cRemove hash.txt
rm hash.txt
Managing Multiple Connections
Add priority flags to each network in wpa_supplicant.conf
default priority=0 (greatest priority goes first)
My prioritized wpa_supplicant.conf:
update_config=1
country=US
network={
priority=1
ssid="NETWORK_A"
psk="password"
network={
priority=2
ssid="NETWORK_B"
proto=RSN
key_mgmt=WPA-EAP
group=CCMP TKIP
There are many more configuration options, run man wpa_supplicant.conf for info.
Ad-Hoc Network / Access Point / Bridge Connection
You want to wireless connect to the pi but there are no available wireless networks. Create your own!
The Raspberry Pi can be set up to broadcast a wireless network. This network allows you to connect the the pi, but will not connect to the internet.
Simple Pi to Pi ad-hoc setup
On Each Rpi
Copy the current file for backup
cp /etc/network/interfaces /etc/network/interfaces.old
Open file to edit
sudo nano /etc/network/interfaces
The only line that should be different in the following file is address everything else should be identical. And you may change the name of your network or add a password
Append the following on Rpi A:
auto wlan0
iface wlan0 inet static
address 192.168.1.1
netmask 255.255.255.0
wireless-channel 1
wireless-essid MYNETWORK
wireless-mode ad-hoc
Append the following Rpi B:
auto wlan0
address 192.168.1.2 `
wireless-channel 1
Save the file and exit the editor
Raise the interface:
sudo ifup wlan0
Scan for ad-hoc networks:
iwlist wlan0 scan
You may add more devices to the network, you just must assign the device a new different static IP address.
The default operating frequency/channel (2.412 GHz: channel 1) is frequently congested. Try using a different channel in the event of difficulties.
Change wireless-channel to a different number
Use sudo iwlist wlan0 scan to find other channels.
src: https://wiki.debian.org/WiFi/AdHoc
Less Simple
More complicated but will connect to known networks and create ad-hoc if none are found.
Follow this tutorial (no ethernet bridge, I have used this successfully) http://www.raspberryconnect.com/network/item/331-raspberry-pi-auto-wifi-hotspot-switch-no-internet-routing
hostname -I
Run this on Pi, Then I connected from to the second IP address listed via ssh pi@[ipaddr] from my Ubuntu host machine.
With ethernet bridge (I have not tested this, but from the same tinkerers as ↑) http://www.raspberryconnect.com/network/item/330-raspberry-pi-auto-wifi-hotspot-switch-internet
KNOWN ERRORS:
Ssh connection fails from host machine to Pi? run with verbose output:
ssh -vvvv pi@raspberrypi.local
If the last commands before close are:
debug1: SSH2_MSG_KEXINIT sent
Connection closed by raspberrypi.local port 22
Try regenerating the host keys they may be missing or corrupt (do this on Pi):
sudo rm /etc/ssh/ssh_host_*
sudo dpkg-reconfigure openssh-server
https://www.raspberrypi.org/forums/viewtopic.php?t=168310
https://www.raspberrypi.org/forums/viewtopic.php?t=111100
https://www.doc.ic.ac.uk/~ajd/Robotics/RoboticsResources/wifi_setup.txt
- 409
- 1
- 5
- 10
Use this easy program I found on Github: Rasp-Connect - Easy python Script to Connect Raspbian to a Wifi Network Using Python.
It is an easy Python script that configures and sets it up for you, you just need to select what encryption type and enter the SSID, and the password. It works very well and also supports running the tool over SSH.
- 2,969
- 5
- 27
- 38
