I have just tried to set static ip on my raspbian.
I have added those line into /etc/dhcpcd.conf
interface INTERFACENAME(ETH0/WLAN0)
static ip_address=192.168.101.46/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
And then I've reboot the raspberry.
when the system start I can login via SSH to the new local ip, but when I try to ping google there is no response. I have tried to put Google DNS 8.8.8.8 but I have not recevied any respond.
Thanks.
BTW - I've seen similar questions over here but I still unable to fix the problem.
Itzik.B
  • 121
If:
Your router subnet is incorrect for your device because the subnet mask says your devices network is 192.168.101 and your router network is 192.168.1.
HTH
ghosts
  • 71
I very much doubt you have an interface INTERFACENAME(ETH0/WLAN0) - there are other obvious errors.
If you absolutely MUST set a static address How to set up Static IP Address explains how to do it.
I still fail to understand why so many Pi users WANT to set a static IP address, particularly when they seem to have little understanding of networking.
@itzikb I think you put wrong address meanwhile in changing IP address process. as @ghost said, your router subnet is incorrect for your device. You have to change your configuration. look at this link might give you answer of your solution.
prince
