I have a Raspberry Pi 3 Model B+. I am currently installing the Pi into a Super Tinytendo case, which came with a built-in mini fan. However, I'm not sure which set of pins I should plug the fan into.
According to the specs, the mini fan is 5 volts. It has two pin holes with red and black cables.
Raspberry Pi 3 Model B+ with a disconnected 2 pin fan
Where do I plug in a 5 volt mini fan on a Raspberry Pi 3 Model B+?
Stevoisiak
  • 321
If your fan is a 5v fan you need 5v (or 3v for slow spinning) and ground pins. If your fan is a 3v fan DO NOT use the 5v pin: use 3v instead.
Raspberry pi has an utility called pinout which tells you the phisical layout of your board. Just open a shell and run:
pinout
The output will be something like:
pinout output
If you prefer to trust documentation, this is the layout the documentation states:
Left side first or second pin for 5v and third for ground. I won't give numbers since they vary depending the schema you follow, so I think providing images is better.
Images: Diagram
Raspberry Pi photo
source: Raspberry Pi GPIO Doc
DGoiko
  • 161
GPIO pins 4 (+5v) and 6 (GND). I peeled back the two leads from a GPIO-to-breadboard ribbon cable and soldered to two female-ended breadboard cable leads and connected them to the GPIO pins.
Pi 3B/Ubuntu Ma'te desktop.
Farad'n
  • 127
soldering leads from the usb power worked best for me allowing the fan to stop when Pi is halted then using gpio3 to wake..
Pi user
