I use omxplayer for videos and fbi for images. My problems is that when command fbi run the nex command will run at the same time. How can I serialize the fbi commands so that images and videos are showed one after the other without big gaps.
fbi -noverbose -nocomments -T 1 -1 -t 10 ${IMGS[$PLAYING]}
let PLAYING+=1
omxplayer -r -o hdmi ${VIDS[$PLAYING2]}
let PLAYING2+=1
let PLAYING+=1
JPX
  • 563
I found this kind of solution. While loop waits until omxplayer and fbi process has ended and then next image or video can be shown.
while ps ax | grep -v grep | grep -E "omxplayer|fbi" > /dev/null; do
    sleep 0.1
done
JPX
  • 563
To avoid having to exclude grep from the results you can use the following while loop
while pgrep -f /usr/bin/fbi || pgrep -f /usr/bin/omxplayer;do
    sleep 0.1
done
sparks
  • 101
You can introduce a short fixed delay of maybe 3 seconds by calling:
sleep 3
or you can prompt for a keypress before continuing, so something like:
read -sn 1
which will only continue with the script when a key is pressed.
Is that the kind of thing you mean?
John Hawthorne
  • 914
You can count total image display time by list all image files in a file and count total number of files say n. If time for one image on screen ex. 3 sec. then total sleep after fbi statement is n x 3 sec
omxplayer process running in foreground hence no problem for omxplayer it cannot let next statement run before it complete.
Above setup is working for me but sometimes screen is blank for image while debugging I found that fbi is running and omxplayer is not running, i.e. processes on system are running as required but I am not getting why screen is blank. Once this happen video is working fine while image always bank. On next reboot it may correct but again after sometime it start happening.
Most chance to happen this when video file size is 18mb or above it. Very rare in case of small video files.
