On my raspberry Pi 3B, attempting to access the internet for downloads fails. Anything that uses it (chromium, apt-get, etc) does not work, giving errors such as DNS server not found, or just hanging. However, ping google.com or ping 10.0.0.1 works just fine (connecting to my Router's setup page via 10.0.0.1 in chromium seems to work also)
This issue occurs on both LAN and WiFi.
I have looked at other forums which have similar issues, but their solutions do not seem to apply - the LAN lights are active on the Ethernet port, the MTU value of all interfaces is set to 1400, and my Router has DHCP enabled (the PI is detected)
  • OS: Raspbian 4.9.80 v7
  • Manufacturer: element14
Fuzzyzilla
  • 139
In cases like this it helps to break the problem down – which in turn means knowing something about the pieces that need to line up for a network connection to succeed. Much of this information isn't specific to the Pi or it's OS, but it will be helpful to know the tools and foibles of the particular hardware and OS that you are using.
This question and its answers may help: How do I set up networking/WiFi/static IP address?.
Testing with other devices on the same network may also help pinpoint where the problem lies. Rebooting often works wonders.
In general you want to start close and expand as you test, so you might:
  1. Check that your network is up and basically working by trying to ping a machine on your local net by IP address (ping 10.0.0.42).
  2. Check that you can talk to your router by attempting to ping the internal interface of your router by IP address (ping 10.0.0.1).
  3. Check that your router is routing by doing a ping to the external interface of your router by IP address (ping 1.2.4.192).
  4. Now try to reach your router's router by attempting to ping your router's default route by IP address (ping 1.2.4.8). Success means that you can reach a remote machine – specifically the machine that your router will be forwarding all of your Internet traffic to
  5. Now verify that it is all working with a to ping something far away by IP address (ping 8.8.8.8).
If those all work then you have a network connection that is working at the IP level. If any of them fail, then that is the spot to start investigating further.
Next test that DNS works. You could:
  1. Use dig to check it DNS requests are getting resolved. Use a well known server by IP address (e.g., 8.8.8.8 or 1.1.1.1) – dig google.com @1.1.1.1
  2. Then try the same thing using the DNS server that you have configured.
  3. Then try pinging a "new" host (one that you're confident isn't in your local resolver cache.
If you don't have dig or nslookup or a similar tool you can use ping instead.
dlu
  • 467
