26
I downloaded RPi.GPIO 5.3a from here: https://pypi.python.org/pypi/RPi.GPIO
I extracted the tar file, cd into the folder and ran:
sudo python setup.py install
It ran through a bunch of stuff and doesn't seem to have failed. The last line of its work is this:
Writing /usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.3a.egg-info
After that it was done and gave me back control.
Now I type
sudo python
then
import RPi.GPIO
and I see
ImportError: No module named GPIO
Can anyone point me to exactly what steps I need to take to get the python GPIO library installed correctly so I can import it and manipulate the GP pins? I've found a mish mash of different processes online (this was the one that came up most often) but I have thus far been unable to get any of them to work.
FoamyGuy
  • 479
5 Answers5
36
Not sure if this is helpful, but under the latest copy of Raspbian I was able to install RPi.GPIO directly from the main repositories using apt-get as follows:
sudo apt-get update
sudo apt-get -y install python-rpi.gpio
If you're running Python 3 (idle3 on the command line) instead of Python 2 (python on the command line) you need to install the RPi.GPIO library with this command instead:
sudo apt-get -y install python3-rpi.gpio
Morgan Courbet
  • 3,703
  • 38
PiBorg
  • 1,537
Assuming you have pip, the python package index installer, which is installed on the latest versions of Raspbian by default You can use: sudo pip install RPi.GPIO for Python 2 and sudo pip-3.2 install RPi.GPIO for Python 3
brainiak4431
  • 171
Another potential cause could be because the RPi.GPIO library has C bindings and therefore need to have python-dev installed in order to compile correctly when installing.
Make sure you've got the python-dev package installed along with the RPi.GPIO package:
sudo apt-get install python-dev python-rpi.gpio
This is the recommended approach on the Adafriuit installation guide:
https://learn.adafruit.com/playing-sounds-and-using-buttons-with-raspberry-pi/install-python-module-rpi-dot-gpio
adam
  • 161
If you are using a fresh image you don’t need to install it.
For the old version
  1. sudo apt-get update
  2. sudo apt-get install rpi.gpio
user121882
This worked for me on my RPi 4B. Just ensure you have the last version of RPi.GPIO but installed from pip (it was newer) than apt-get:
Remove current RPi.GPIO versions:
sudo apt-get purge python{,3}-rpi.gpio
Update pip first:
sudo -H pip2 install --upgrade pip
sudo -H pip3 install --upgrade pip
Install RPi.GPIO from updated pip:
python -m pip install RPi.GPIO
python3 -m pip install RPi.GPIO
