So, I am developing a project in the RPi where I will be reading values from a sensor using I2C, and this values will be plotted in real time using a GUI. The project is strictly being developed C++ (we are extensively using C++ libraries ) so no Python is allowed.
I've thoroughly searched for C++ GUI options and come up with the very well known Qt and GTK.
So, Qt. I started developing the GUI on my laptop and everything worked fine, I pulled off the graphs using Qt Charts (which is not in the main installation) and they worked good with simulated sensor values. However, when I moved to the RPi I tried opening the project and of course Qt Charts was missing, I googled a lot but I didn't find a way of installing it on the RPi. I am a bit doubtful if maybe I got over the line and this was just as easy as add the library but I am really doubtful. So also if anyone knows this, please help.
Now, GTK. I downloaded Glade and was getting the hang of how it works and everything, but before going further I decided checking if there were available tools for plotting. I found gnuplot and whatnot libraries interfacing it, gtkgraph (which seems deprecated) and even a suggestion of making my own widget using cairo and tbh I am thinking GTK is not the way to go either.
So, for all you community out there do you have any suggestion on how should I proceed ? Maybe another C++ GUI tool? Or another GTK or Qt library suggestion that is known to work with the RPi? I am even thinking of messing up with graphics directly(OpenCV and that) but I am not sure how difficult it might turn out.
Thanks in advance and any advice is welcomed.
I'm not sure what exactly you have tried to install Qt Charts, but there's qml-module-qtcharts package you can install with apt-get. Alternatively, you could build Qt Charts from source. According to their build instructions, it should be as easy as running
qmake CONFIG+=debug
make
sudo make install
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
