I'm trying to output video content on the Pi without X11. I'd like to use tvservice to set the resolution settings then be able to run pipelines like this:
gst-launch-1.0 videotestsrc ! videoconvert ! fbdevsink
I see that /dev/fb0 exists, and I can write to it without errors, e.g.:
cat `which bash` > /dev/fb0
But I just end up with a blank screen. My gpu_mem in config.txt is set to 128meg. If it matters my current tvservice is:
state 0x120006 [DVI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
mpr
  • 161
It turns out this issue had to do with having called tvservice to change the screen resolution. Apparently after this is done a corresponding call needs to be made to fbset.
So for example if I go to DMT mode 16 (1920x1080):
tvservice -e "DMT 16
I need to follow that up with:
fbset -g 1920 1080 1920 1080 16
Now fbdevsink works. omxplayer seems to work regardless because it somehow goes around the frame buffer.
mpr
  • 161
