I tried many fixes, but most of them are for NOOBS Raspbian installations, not for a clan Raspbian installation.
I got the following Kernel Panic error:
Kernel panic-not syncing: VFS: unable to mount root fs on unknown- block(179,2)
I tried changing the cmdline.txt file as most places suggest:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=eda198d5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
To this:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=eda198d5-06 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
But I got a new error:
Kernel panic-not syncing: VFS: unable to mount root fs on unknown- block(179,6)
This time ending with (179,6)
Joshua Salazar
  • 131
I used @Dr Beco s answer:
To deal with the core of the problem (not a workaround), if you can't boot (or you have no "NOOBS"), you need to:
  • remove the SD card from your Pi and put it in a card reader in your linux computer.
  • if automatically mounted, umount both partitions. Check the correct device name with fdisk -l and mount -l. In my example, it is mounted as /dev/sdb1 and /dev/sdb2. So, to unmount, use umount /dev/sdb1 and umount /dev/sdb2. (BE CAREFULL TO CHECK YOUR PARTITION NUMBER. "2" here is just MY example).
  • Now you are ready to proceed the check-up with corrections.
    • With fdisk -l identify the DOS partition and check/fix it with fsck.fat -y /dev/sdb1 (Check your correct number)
    • Also, fdisk -l shows you the ext4 partition number. Fix it with fsck.ext4 -y /dev/sdb2 (Check your correct number)
  • If it automount again, umount both again. If not, you are ready to remove from your computer to your Raspberry Pi and turn it on.
If it is just a "block" issue, it will probably be up and running. If the Kernel Panic continue, check if the error message has changed to something else. In this case, you should look again for other answers, or maybe consider re-writing your SD Card from scratch.
After that, everything worked fine. (Note that I returned to my original cmdline.txt configuration)
Joshua Salazar
  • 131
I tried to follow other's solution with no luck. I had no sudo in the recovery commandline.
I had this error:
Kernel panic-not syncing: VFS: unable to mount root fs on unknown- block(179,7)
What I did:
  1. boot raspberry
  2. hold shift
  3. do alt+F2 to go to commandline
  4. login as root:raspberry > command line #-sign is visible
  5. fdisk -l to check what partition
  6. fsck.ext4 -y /dev/[partition you want]
hope it helps
Tim
