I installed node.js on my Raspberry Pi. But now I'm wondering what database I should use for it.
I'd like it to be an easy solution. The easier to work with / fast installation / the better.
I saw a lot of people like sqlite, but they mostly use it with Python. Also, I'm a bit iffy on using a SQL database. I'd like something easier to work with especially saving/loading JavaScript objects, perhaps NoSQL. But I noticed that NoSQL solutions like mongodb are a bit hard to use with Raspberry Pi since I need to compile it, etc.
So, what database would you recommend for RaspberryPi + Node.js ?
elixenide
  • 210
foreyez
  • 173
Unless you have a need for many concurrent users or processes writing to the database at the same time I would recommend sqlite. It is file based so you don't need a server running, and each project can use its own database file (unless they need to share data). If you use a database abstraction layer you can move to mysql or postgres without too much trouble in the future.
And, as a bonus, doing a backup is a simple file copy.
Craig
  • 3,014
I'm actually using OrientDB together with node in my raspberry pi. www.orientdb.org
Installation wise, its just a simple wget from the site downloads page and then launching ./bin/server.sh
They even have a useful webadmin tool at yoururl:2480 by default.
It's NOSQL too and so far my experience of it is like having a database of JS objects that are linked together in a graph network. Best thing is I can use good old SQL queries to retrieve all the JS objects I want, those are linked to them, etc etc.
unclelim12
  • 175
Better late than never, when trying to figure out an answer for the same question myself I found this https://github.com/louischatriot/nedb - pure Node.js database, will run on every Node (I hope) and it's NoSQL.
What project are you trying to do? The database should be selected with the project in mind. I've run MySql paired with memcached with great results.
vlad b.
  • 262
