I'm creating a network testing tool (educational project) at work which is to be used by non technical staff. I have created a simple GUI with buttons for preconfigured IP addresses, of which I can manipulate the static IP address and the subnet mask of the Pi.
The only problem is that I can't find a way to change the default gateway in the same command (or at all using Python).
I'm currently using:
def setIP_XXX():
os.system('sudo ifconfig eth0 down')
os.system('sudo ifconfig eth0 192.xxx.xxx.xx/24')
os.system('sudo ifconfig eth0 up')
Any help in this area would be great as it's starting to become a very stressful experience.
Ghanima
  • 15,958
  • 65
lgeoghegan
If your network doesn't provide you gateway for some reason, then your route table will be empty. Use below command to check it after connecting to a network
$ route -n
If, it's empty then do this
$ route add default gw {gateway-ip} {interface-name}
You can also set netmask along with IP
Example:
$ sudo ifconfig {interface-name} 192.168.1.XX netmask 255.255.255.0
Arpit Agarwal
  • 581
Try out the pyroute2 library that has the functions you are looking for.
https://github.com/svinota/pyroute2
MatsK
  • 2,882
  • 22
