So I'm having trouble getting my printer to work, I installed CUPS and it seems to be working correctly. I downloaded and installed the drivers for the printer from the Brother website from here: http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=mfcj430w_all
However, when I run the installer or try to print something using lpr -P MFCJ430W /usr/share/cups/data/testprint I get this error:
lpr: connect: No such file or directory
Is lpd daemon running?
jobs queued, but cannot start daemon.
When I run sudo service lpd status it shows active with the following errors
Mar 05 05:19:26 Nathan-Raspberry-Pi-1 lpd[1477]: MFCJ430W: filter 'f'
exited (retcode=255 prog=/opt/brother/Printers/mfcj430w/lpd/filtermfcj430w)
Mar 05 05:19:26 Nathan-Raspberry-Pi-1 lpd[1477]: mail sent to user user about job testprint on printer MFCJ430W (FILTERERR)
If I try to print something using lp -d MFCJ430W ~/testFile.txt I get request id is MFCJ430W-42 (1 file(s)) but nothing prints. Also, nothing prints from the CUPS webpage.
My printer is connected via USB and I'm running Raspbian Jessie. Has anyone had this before or fixed it? Note: i'm not running on the default user pi, but I have sudo privileges. Thanks, any help would be appreciated!
EDIT: This is how I run the installer and what it returns up to the the point of the error:
user@Nathan-Raspberry-Pi-1:~ $ sudo bash linux-brprinter-installer-2.2.0-1 [sudo] password for user: Input model name ->mfcj430w
You are going to install following packages. mfcj430wlpr-3.0.1-1.i386.deb mfcj430wcupswrapper-3.0.0-1.i386.deb brscan4-0.4.4-3.i386.deb brscan-skey-0.2.4-1.i386.deb OK? [y/N] ->y
dpkg -x mfcj430wlpr-3.0.1-1.i386.deb / dpkg -x mfcj430wcupswrapper-3.0.0-1.i386.deb / (Reading database ... 47006 files and directories currently installed.) Removing mfcj430wcupswrapper:i386 (3.0.0-1) ...
[ ok ] Restarting cups (via systemctl): cups.service.
Purging configuration files for mfcj430wcupswrapper:i386 (3.0.0-1) ... dpkg-deb: building package 'mfcj430wlpr' in 'mfcj430wlpr-3.0.1-1a.i386.deb'. dpkg -b ./brother_driver_packdir mfcj430wlpr-3.0.1-1a.i386.deb dpkg-deb: building package 'mfcj430wcupswrapper' in 'mfcj430wcupswrapper-3.0.0-1a.i386.deb'. dpkg -b ./brother_driver_packdir mfcj430wcupswrapper-3.0.0-1a.i386.deb dpkg -i --force-all mfcj430wlpr-3.0.1-1a.i386.deb (Reading database ... 47002 files and directories currently installed.) Preparing to unpack mfcj430wlpr-3.0.1-1a.i386.deb ... Unpacking mfcj430wlpr:i386 (3.0.1-1) over (3.0.1-1) ... Setting up mfcj430wlpr:i386 (3.0.1-1) ... dpkg -i --force-all mfcj430wcupswrapper-3.0.0-1a.i386.deb Selecting previously unselected package mfcj430wcupswrapper:i386. (Reading database ... 47002 files and directories currently installed.) Preparing to unpack mfcj430wcupswrapper-3.0.0-1a.i386.deb ... Unpacking mfcj430wcupswrapper:i386 (3.0.0-1) ... Setting up mfcj430wcupswrapper:i386 (3.0.0-1) ...
Stopping printer spooler: lpd [not running]
lpadmin -p MFCJ430W -E -v usb://Brother/MFC-J430W?serial=BROC2F220236 -P /usr/share/cups/model/Brother/brother_mfcj430w_printer_en.ppd
Will you specify the Device URI? [Y/n] ->n
Test Print? [y/N] ->y
wait 5s. lpr -P MFCJ430W /usr/share/cups/data/testprint lpr: connect: No such file or directory Is lpd daemon running? jobs queued, but cannot start daemon.
I have been trying to follow this tutorial: https://davesteele.github.io/raspberrypi/2016/04/23/raspberry-pi-cloudprint/
Nathan O
  • 99
