29
I have bought a Model A Pi, and I successfully configured it with a USB Wifi dongle on Raspbian. I recently prepared an SD card with the latest version of Arch Linux ARM and I am trying to get it set up with WiFi. I was trying to follow a Raspbian WiFi tutorial (thinking it could be the same as Arch Linux ARM) which said that there is a directory /etc/network/ and you could set up WiFi from the interface file, but no directory /etc/network/ exists. I heard about netctl but I have no Idea how to use it! I do have a supported USB WiFi dongle. Could someone please show me how I can setup WiFi on Arch Linux ARM? Thanks!
Steve Robillard
  • 34,988
  • 106
  • 110
user151324
  • 1,270
The deprecated netcfg used /etc/network.d/ to store profiles. The successor of netcfg is netctl.
In order to setup a wireless network, install netctl using sudo pacman -S netctl. Next, you have to create a network profile. /etc/netctl/examples/ contains some examples. Let's assume you want to setup a WPA2-PSK network. Simply copy over the example file and start editing:
/etc/netctl# install -m640 examples/wireless-wpa wireless-home
/etc/netctl# cat wireless-home
Description='A simple WPA encrypted wireless connection'
Interface=wlan0
Connection=wireless
Security=wpa
IP=dhcp
ESSID='MyNetwork'
# Prepend hexadecimal keys with \"
# If your key starts with ", write it as '""<key>"'
# See also: the section on special quoting rules in netctl.profile(5)
Key='WirelessKey'
# Uncomment this if your ssid is hidden
#Hidden=yes
Edit MyNetwork and WirelessKey as needed. Note the 640 permissions, you do not want to leak your wireless passphrase to the world!
Proceed with testing:
# netctl start wireless-home
If you do not get an error, you should be connected. Let's test this:
$ ping 8.8.8.8
To make this network start on boot:
# netctl enable wireless-home
Lekensteyn
  • 1,521
This didn't work for me at first. After following the above instructions, I had to run
systemctl enable netctl-auto@wlan0
to make it work. I found the answer at the ArchLInux Arm Forum
user12295
  • 71
