I'm trying to use realtek 8188cu module in concurrent mode(both station and AP mode simultaneously). I downloaded the driver source files from here: https://github.com/raspberrypi/linux/tree/204050d0eafb565b68abf512710036c10ef1bd23/drivers/net/wireless/realtek/rtl8192cu
And I modified the include/autoconf.h: enabled the commented out line: #define CONFIG_CONCURRENT_MODE 1
i'm running the latest stable release for raspbian lite: 4.9.59-v7+
I downloaded the linux kernel files by running rpi-source --skip-gcc
And I built the kernel module using the command: make -C /lib/modules/$(uname -r )/build M=$(pwd) modules
The compilation succeeded without giving me any errors, but upon inspecting the 8192cu.ko file generated after compilation, I find out that its compiled to the wrong kernel version. Below is the vermagic information when I ran modinfo ./8192cu.ko:
vermagic: 4.9.58-v7+ SMP mod_unload modversions ARMv7 p2v8
Tried modprobing the .ko file. Did not work.
But I don't even have kernel sources for 4.9.58-v7+.. What is going on? Can somebody help me to compile the driver successfully and to get it working with latest raspbian stable release?
Thanks
