If so, how? I'm using Raspbian Stretch. I looked in the Openbox config manager and keyboard and mouse configuration. I would like to move the pointer without a mouse using the arrow keys.
Aurora0001
  • 6,357
  • 25
  • 39
Sjors123
  • 81
This command lets you control the mouse with the numpad, so not exactly what you asked for, but with this you do not need to install anything or edit any files:
setxkbmap -option keypad:pointerkeys
Press CTRL + SHIFT + NUMLOCK to activate.
From: http://en.linuxreviews.org/HOWTO_use_the_numeric_keyboard_keys_as_mouse_in_XOrg
Albert
  • 111
I Don't really know whats your intent if you want to start a program or something you can use key shortcuts
  • [Ctrl] [Esc] - Will bring up the start menu where you can select and
  • [Alt] [F2] - Will start a run command box.
  • [ESC] to exit
  • [Alt] [F4] -Terminate running application(s) beginning with most recent.
  • [Ctrl] [Alt] [Delete] - Bring up task manager
Or you can use the xwit library
 sudo apt-get install xwit xdotool
Now Ctrl+Alt+Keypad buttons moves the cursor.
Or you can use this script by editing this file
~/.config/openbox/lxde-rc.xml
and placing the following into the <keyboard> tag:
<!-- Controlando o MOUSE via LXDE com XWIT -->
  <!-- Keybinding for MOUSE CONTROL RIGHT DOWN-->
  <keybind key="C-A-KP_3">
   <action name="Execute">
         <command>xwit -root -rwarp 5 5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL RIGHT UP-->
  <keybind key="C-A-KP_9">
         <command>xwit -root -rwarp 5 -5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL LEFT DOWN-->
  <keybind key="C-A-KP_1">
         <command>xwit -root -rwarp -5 5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL LEFT UP-->
  <keybind key="C-A-KP_7">
         <command>xwit -root -rwarp -5 -5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL LEFT-->
  <keybind key="C-A-KP_4">
         <command>xwit -root -rwarp -5 0</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL RIGHT-->
  <keybind key="C-A-KP_6">
         <command>xwit -root -rwarp 5 0</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL UP-->
  <keybind key="C-A-KP_8">
         <command>xwit -root -rwarp 0 -5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL DOWN-->
  <keybind key="C-A-KP_2">
            <command>xwit -root -rwarp 0 5</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL DOWN FAST-->
  <keybind key="S-C-A-KP_2">
            <command>xwit -root -rwarp 0 25</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL RIGHT CLICK-->
  <keybind key="C-A-KP_0">
         <command>xdotool click 3</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL MIDLE CLICK-->
  <keybind key="C-A-KP_Decimal">
         <command>xdotool click 2</command>
   </action>
  </keybind>
  <!-- Keybinding for MOUSE CONTROL LEFT CLICK-->
  <keybind key="C-A-KP_Enter">
         <command>xdotool click 1</command>
   </action>
  </keybind>
  <!-- CONROLE DO MOUSE COMUM -->
For the changes to take effect, run
openbox --reconfigure
I hope that's helpful
Ansa211
  • 103
Tarek
  • 141
I know this is a bit old but I am sure this will help somebody. None of the other two posts helped me, at least without modification.
My system is a Rasbian Buster on a Raspberry Pi 4 using an English US keyboard.
So I am using a modification of Tarek's answer. The issue with that answer is that the file that needed edited was not correct. I also thought that I was having issues with the key maps but that turned out to not be the case. Since I had already changed the keys to work without NumLock on I went ahead and left that but also included all the same commands with NumLock so it works both ways.
You will still have to install xwit ad xdotoll.
sudo apt install xwit xdotool
Instead of ~/.config/openbox/lxde-rc.xml I needed to edit ~/.config/openbox/lxde-pi-rc.xml
nano ~/.config/openbox/lxde-pi-rc.xml
If this file does not exist you can copy it from here /etc/xdg/openbox/lxde-pi-rc.xml using this command:
cp /etc/xdg/openbox/lxde-pi-rc.xml ~/.config/openbox/
You may also need to make the ~/.config/openbox directory first using:
mkdir ~/.config/openbox
The following is the XML which you would insert into that file to control the mouse. This will go between <keyboard> and </keyboard>. Preferably at the very end or beginning so its easy to find and definitely not interfering with any other <> </> that is already there. The modifications I made compared to the one posted by Tarek are:
  • I added key maps to use without numlock on.
  • I rearranged the movements to one that made more sense to me.
  • I added a fast version of each movement for while holding shift as recommended by the original author.
  • Last but not least I re-added the original author's credit comment to the end.
 <!-- Control Mouse using Keyboard via XWIT and XDOTOLL -->
   <!-- MOUSE CLICKS WITHOUT NUMLOCK -->
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL MIDDLE CLICK-->
      <keybind key="C-A-KP_Delete">
       </action>
      </keybind>
      <keybind key="C-A-KP_Insert">
       </action>
      </keybind>
   <!-- MOUSE MOVEMENTS WITHOUT NUMLOCK -->
      <keybind key="C-A-KP_Up">
       </action>
      </keybind>
      <keybind key="C-A-KP_Down">
       </action>
      </keybind>
      <keybind key="C-A-KP_Left">
       </action>
      </keybind>
      <keybind key="C-A-KP_Home">
       </action>
      </keybind>
      <keybind key="C-A-KP_End">
       </action>
      </keybind>
      <keybind key="C-A-KP_Right">
       </action>
      </keybind>
      <keybind key="C-A-KP_Prior">
       </action>
      </keybind>
      <keybind key="C-A-KP_Next">
       </action>
      </keybind>
   <!-- FAST MOUSE MOVEMENTS WITHOUT NUMLOCK -->
      <!-- Keybinding for MOUSE CONTROL UP FAST-->
      <keybind key="S-C-A-KP_Up">
             <command>xwit -root -rwarp 0 -25</command>
       </action>
      </keybind>
      <keybind key="S-C-A-KP_Down">
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL LEFT FAST-->
      <keybind key="S-C-A-KP_Left">
             <command>xwit -root -rwarp -25 0</command>
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL LEFT UP FAST-->
      <keybind key="S-C-A-KP_Home">
             <command>xwit -root -rwarp -25 -25</command>
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL LEFT DOWN FAST-->
      <keybind key="S-C-A-KP_End">
             <command>xwit -root -rwarp -25 25</command>
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL RIGHT FAST-->
      <keybind key="S-C-A-KP_Right">
             <command>xwit -root -rwarp 25 0</command>
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL RIGHT UP FAST-->
      <keybind key="S-C-A-KP_Prior">
             <command>xwit -root -rwarp 25 -25</command>
       </action>
      </keybind>
      <!-- Keybinding for MOUSE CONTROL RIGHT DOWN FAST-->
      <keybind key="S-C-A-KP_Next">
             <command>xwit -root -rwarp 25 25</command>
       </action>
      </keybind>
      <!-- MOUSE CLICKS WITH NUMLOCK ON -->
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
   <!-- MOUSE MOVEMENTS WITH NUMLOCK ON -->
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
       </action>
      </keybind>
   <!-- Fast Mouse Movements -->
      <keybind key="S-C-A-KP_8">
       </action>
      </keybind>
       </action>
      </keybind>
      <keybind key="S-C-A-KP_4">
       </action>
      </keybind>
      <keybind key="S-C-A-KP_7">
       </action>
      </keybind>
      <keybind key="S-C-A-KP_1">
       </action>
      </keybind>
      <keybind key="S-C-A-KP_6">
       </action>
      </keybind>
      <keybind key="S-C-A-KP_9">
       </action>
      </keybind>
      <keybind key="S-C-A-KP_3">
       </action>
      </keybind>
          Adriano H. Hedler - LXDE Translation to Portuguese-BR Helper
          Accessibility Option on LXDE
          Brasil - ParanĂ¡ - Curitiba
          Site: www.templosite.com
 <!-- End Control Mouse using Keyboard -->
*Note: I put Mouse Right Click in both with and without numlock sections even though KP_Enter is the same for both so that you can copy one whole section if you don't want to use both.
Once you have made this file you will need to either reboot or execute:
A couple other notes. You can change the speed of the scrolling by changing the values in the xwit command notice the difference between MOUSE UP and MOUSE UP FAST
MOUSE UP:      xwit -root -rwarp 0 -5
MOUSE UP FAST: xwit -root -rwarp 0 -25
Also, if you have a different keyboard layout or for some other reason these key codes are not working for you or you just want to change these controls, you can find out the code for your buttons by executing the command:
xev -event keyboard
The output will look something like this when you press a key:
KeyPress event, serial 25, synthetic NO, window 0x1e00001,
    root 0x369, subw 0x0, time 2252742, (107,658), root:(1462,769),
    state 0x0, keycode 80 (keysym 0xff97, KP_Up), same_screen YES,
    XLookupString gives 0 bytes:
    XmbLookupString gives 0 bytes:
    XFilterEvent returns: False
You are lookingn for the part on the third line down where it says:
Either the 0xff97 or the KP_UP in this example will work in the file.
