I'm unable to get an ethernet connection with a raspberry Pi 2 over a cat7 cable of 40m. It works with my laptop, works over a short cable with same Pi. I used a same alimentation cable of 2.0A 5V
Cat7 cable
The reason I choosed cat7 cable was the price which was just 10% more and the perfs of this cable are better
Working
  • cable tested with a multimeter, every pins are working
  • Laptop connected to that same cable is working
  • Pi connected to LAN with short "normal" ethernet cable
  • I could get it work without problem twice and then disappeared!
Not working
  • two different raspberry pi hardware connected on this cable
Ping traces
20180220_1200
--- 192.168.0.17 ping statistics ---
6474 packets transmitted, 2843 received, 56% packet loss, time 6538201ms
rtt min/avg/max/mdev = 0.823/1.035/1.151/0.041 ms
Philippe Gachoud
  • 277
  1. Seems that an electronic contact spray into the raspberry pi ethernet connector solved my problem!
    --- molezonP2 ping statistics (1000 as packetsize) --- 415 packets transmitted, 415 received, 0% packet loss, time 419263ms
  2. Unfortunately for a time and after a physical disconect/reconnect it didn't work anymore again... got again 56% of packets loss
  3. After 3 days without touching it but connected got again a 0% packets loss
Philippe Gachoud
  • 277
