I'm trying to make a survaillance system with UV4L i already succeed to play i live streaming and record the live stream from UV4L the problem is that when UV4L detects more than 3 users it blocks the other users.
I'm using a basic html to access the stream like
<img src="http://raspberry:8080/stream/video.mjpeg">
I was wonder if there's a way i could allow more than 3 users because when i'm recording in the same link although it is from local host it count as a user.
I already check this solution but it seems the problem is diferent i'm not trying to use the video room but just access the stream from the video.mjpeg.
what i need to change is this: max. simultaneous streams allowed: 3, max. threads: 5. this info is on the webRTC interface when you are in the server info, as you can see it says it can only stream 3 users at a time.
