Is there an easy way to play an MP3 song automatically, and/or loop/or have it play through a series of songs in a folder? I am trying to do this on a Zero and am stuck. I have a Phat Dac connected to it that works brilliantly with lineout speakers.
Basically, I just want to turn on and have white noise machine without doing anything else.
It will play a wav file in the terminal but not loop or go through a folder.
To execute a command at system startup, without the need to login, so you don't need a screen at all, edit the file /etc/rc.local.
sudo nano /etc/rc.local
Paste any command there, and make sure the file end with exit 0.
Also make sure to use the full path to link your audio file.
#!/bin/sh -e
aplay /home/pi/Music/noise.wav
exit 0
aplay is a command line player that should be installed by default.
Then give execution rights, so the file get executed at system startup:
sudo chmod +x /etc/rc.local
To specifically generate white/pink noise, add audio effects and many more, other advanced tools can do that, like ffmpeg or sox.
NVRM
  • 159
You should use a systemd unit file to run a program at startup. Try this simple Unit to start with your project. If it runs on bootup you can improve it step by step.
Create a new service with
rpi ~$ sudo systemctl --force --full edit my-startup-song.service
In the empty editor insert these statements, save them and quit the editor:
[Unit]
Description=Play song at startup
After=multi-user.target
[Service] ExecStart=/usr/bin/aplay /full/path/to/noise.wav
[Install] WantedBy=multi-user.target
Enable the new service with:
rpi ~$ sudo systemctl --now enable my-startup-song.service
Instead of the example with aplay use the player of your choice, maybe mpg123.
Ingo
  • 42,961
  • 207
Yes, use a shell script, that triggers your favorite mp3 wav player via command line.., you can customize a script file to do all sorts of nifty commands like cycle through all tracks.. and have that script load up in an rc.local file to trigger at startup.
Lots of ways you can do this, I'm sure you might be able to load a gui based player via command line with a playlist file of tracks or one track, and pass it parameters like volume, file, repeat all etc
You will need to find a good player to suit your needs and do a little research on scripting if you go that route.
I find the nifty Node-Red flowchart based programming IDE can open a wide world of awesome possibilities with interactive fun stuff, and makes programming things like that a little simpler, but might be Overkill for a simple scripts task.
mrSidX
  • 618
