I'd like to control my Raspberry pi 3 Model B (using raspbian stretch) using a web interface accessible from any device able to connect to a WiFi generate by the Raspberry Pi.
Idealy, once you're connected to this WiFi with your device (smartphone, tablette or computer), you could control the Raspberry just by going to his IP adress with any browser you want.
Okay but the thing is I want to do that in field condition without any internet access via an ethernet cable. I don't want to go on internet by creating an Hotspot to share a connexion, I just want to access and control the Raspberry.
So is this possible ?
Oryos
Yes, there is no requirement that you set up a bridge or router with your wifi hotspot configuration, but this is a common thing so often included in examples. Simply skip the bridging portion of any guide or tutorial you are following
Creating a Wifi hotspot with internet access requires bridging to another interface with internet access e.g. wired Ethernet.
The hotspot and radio mode is managed by Linux wireless tools and drivers, routing is managed by the kernel directly.
crasic
  • 3,033
Lets break the problem in to two part (a) and (b) solutions.
(a) You want to offer a wireless AP to others from your RPi (b) You want to be able to directly connect to your RPi to control, change it but not using the wireless AP, correct?
If so I suggest you solve both separately. Get your wireless AP to work first. Then you could for example enable Ether over USB - to directly connect to your RPi and control it.
Mark
  • 145
