I have been trying to setup up WiFi with my Raspberry Pi Model A (meaning I don't have a internet connection currently), running Raspbian 2013. I have tried several things to setup my WiFi but none of them worked:
The manual approach:
http://learn.adafruit.com/adafruits-raspberry-pi-lesson-3-network-setup/setting-up-wifi-with-occidentalis
This gave me boot errors, and I never was able to connect to the internet.
The GUI approach:
http://learn.adafruit.com/adafruits-raspberry-pi-lesson-3-network-setup/setting-up-wifi-with-raspbian
My network flag is WEP, and it has a pass-phrase but wpa_config never asked for one and I was unable to connect.
I have tried several other different approaches but they all led down to these 2 basic approaches...
I am using a Tenda USB WiFi adapter that is compatible with my Pi, and my network is a WEP network with a password. Any suggestions? Thanks!
Steve Robillard
  • 34,988
  • 106
  • 110
user151324
  • 1,270
Both those approaches you've linked are WPA based. If your network really is WEP, it's a slightly different process. Try editing the /etc/wpa_supplicant/wpa_supplicant.conf file and adding something like this:
network={
    ssid="static-wep-test"
    key_mgmt=NONE
    wep_key0="abcde"
    wep_key1=0102030405
    wep_tx_keyidx=0
    priority=5
If that doesn't work you can try configuring it manually from the command line with the iwconfig utility:
iwconfig wlan0 essid "MyNetwork" key "s:password"
Drop the "s:" if your WEP key is a hexadecimal code rather than a string password. (In the wpa_supplicant example use "" for a password and without for a hexadecimal code.)
Fred
  • 4,592
  • 29
