I want to use the Raspberry Pi as a VPN gateway. The RPi connects to my home network and the internet via wlan0, and any device plugged into eth0 gets a VPN connection. I am using pptp-linux to make the VPN connection and everything worked fine during my prototyping stage. However, to complete the project I have put the VPN connection in the /etc/rc.local script so that it will start at boot. Now it fails 50% of the time. I suspect that it is attempting the VPN connection before I am properly connected to the internet via wlan0. If this is the problem, I need a test for a valid internet connection at the beginning of rc.local before proceeding with the rest of the script.
Any ideas as to how I could do this?
Asked
Active
Viewed 4.0k times
user151324
- 1,270
- 4
- 14
- 17
user7848
- 81
- 1
- 1
- 2
From this StackOverflow answer;
Ping your local gateway;
#!/bin/bash ping -q -w 1 -c 1 `ip r | grep default | cut -d ' ' -f 3` > /dev/null && echo ok || echo error
right off the top of my head:
ping your router
ping google.com
grep
ifconfigoutput for valid gateway and/or valid IP address
lenik
- 11,533
- 2
- 32
- 37
Based on Jivings sample code and some of my own logic.
#!/bin/bash
STATE="error";
while [ $STATE == "error" ]; do
#do a ping and check that its not a default message or change to grep for something else
STATE=$(ping -q -w 1 -c 1 `ip r | grep default | cut -d ' ' -f 3` > /dev/null && echo ok || echo error)
#sleep for 2 seconds and try again
sleep 2
done
#put your VPN code here...
The proper way would be to create a function that returns a boolean on the while comparator. but this is how the shell logic should look like.
Piotr Kula
- 17,336
- 6
- 66
- 105
Debian now uses upstart. This is probably a much simpler way of doing it that init.d scripts.
You may need to try a few different services to wait on, but networking (if it's there) or network-manager might be a good ones to try first.
This is for Ubuntu, but you shouldn't find too many differences http://upstart.ubuntu.com/cookbook/
KayEss
- 346
- 1
- 6
