My Pi is rebooting for no obvious reason. Each time it reboots, syslog has a line that says the system is rebooting, so something must be causing it. I wrote a script to log which processes are running so I can match the PID in syslog with the active tasks. I used chkconfig to set it to run at level 6 -- the reboot level, and I changed the /etc/rc6.d/K-number for my task to be sooner rather than later -- but my task is not running when the system reboots.
I considered trying to use crontab -e to run my task, but in crontab, @reboot means run when the system is starting, not when it's stopping.
How can I run my task when the system is rebooting so I can find what's causing the problem ?
Thank you in advance.
Feb 1: As requested, here's text from syslog immediately before and after one of the shutdown requests (shown by --->>>):
Jan 28 15:42:30 T-1 pppd[3569]: Using interface ppp0
Jan 28 15:42:30 T-1 pppd[3569]: Connect: ppp0 <--> /dev/ttyUSB3
Jan 28 15:42:30 T-1 kernel: [  155.052123] PPP BSD Compression module registered
Jan 28 15:42:30 T-1 kernel: [  155.107169] PPP Deflate Compression module registered
Jan 28 15:42:30 T-1 pppd[3569]: local  IP address 166.145.88.33
Jan 28 15:42:30 T-1 pppd[3569]: remote IP address 66.174.121.64
Jan 28 15:42:30 T-1 pppd[3569]: primary   DNS address 198.224.186.135
Jan 28 15:42:30 T-1 pppd[3569]: secondary DNS address 198.224.187.135
Jan 28 15:42:32 T-1 ntpd[2676]: Listen normally on 3 ppp0 166.145.88.33 UDP 123
Jan 28 15:42:32 T-1 ntpd[2676]: peers refreshed
Jan 28 15:42:32 T-1 ntpd_intres[2684]: DNS 0.north-america.pool.ntp.org ->
162.210.111.4
Jan 28 15:42:32 T-1 ntpd_intres[2684]: DNS 1.north-america.pool.ntp.org -> 129.250.35.251
Jan 28 15:42:32 T-1 ntpd_intres[2684]: DNS 2.north-america.pool.ntp.org -> 198.55.111.50
Jan 28 15:42:32 T-1 ntpd_intres[2684]: DNS 3.north-america.pool.ntp.org -> 206.108.0.132
Jan 28 15:42:33 T-1 ntpd_intres[2684]: DNS 0.debian.pool.ntp.org -> 185.143.194.7
Jan 28 15:42:33 T-1 ntpd_intres[2684]: DNS 1.debian.pool.ntp.org -> 178.33.111.49
Jan 28 15:42:33 T-1 ntpd_intres[2684]: DNS 2.debian.pool.ntp.org -> 185.51.192.34
Jan 28 15:42:33 T-1 ntpd_intres[2684]: DNS 3.debian.pool.ntp.org -> 162.23.41.56
Jan 28 15:42:38 T-1 kernel: [  162.901504] tun: Universal TUN/TAP device driver, 1.6
Jan 28 15:42:38 T-1 kernel: [  162.901520] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jan 28 15:42:40 T-1 ntpd[2676]: Listen normally on 4 tun0 10.221.0.53 UDP 123
Jan 28 15:42:40 T-1 ntpd[2676]: peers refreshed
Jan 28 15:44:20 T-1 kernel: [  264.553863] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Jan 28 16:17:03 T-1 kernel: [ 2227.634289] rtc rtc0: __rtc_set_alarm: err=-22
Jan 28 16:17:09 T-1 kernel: [ 2233.700531] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 28 16:55:32 T-1 kernel: [ 4536.916200] device wlan0 left promiscuous mode
Jan 28 16:55:40 T-1 kernel: [ 4544.603733] device wlan0 entered promiscuous mode
Jan 28 18:00:04 T-1 kernel: [ 8408.971851] device wlan0 left promiscuous mode
Jan 28 18:00:12 T-1 kernel: [ 8416.412629] device wlan0 entered promiscuous mode
Jan 28 18:33:07 T-1 kernel: [10391.538366] device wlan0 left promiscuous mode
Jan 28 18:33:12 T-1 kernel: [10397.096754] device wlan0 entered promiscuous mode
Jan 28 20:13:12 T-1 shutdown[29119]: shutting down for system reboot
Jan 28 20:13:12 T-1 init: Switching to runlevel: 6
Jan 28 20:13:20 T-1 ntpd[2676]: ntpd exiting on signal 15
Jan 28 20:13:20 T-1 pppd[3569]: Terminating on signal 15
Jan 28 20:13:20 T-1 pppd[3569]: Connect time 270.9 minutes.
Jan 28 20:13:20 T-1 pppd[3569]: Sent 139485060 bytes, received 19038810 bytes.
Jan 28 20:13:20 T-1 pppd[3569]: Connection terminated.
Jan 28 20:13:20 T-1 kernel: [16404.301032] device wlan0 left promiscuous mode
Jan 28 20:13:20 T-1 pppd[3569]: Exit.
NewtownGuy
  • 119
I assume you are using an operating system like Raspbian since version Jessie. Then you can use a simple systemd Unit file to run a script at shutdown. Just create a new service with:
rpi ~$ sudo systemctl --force --full edit log-shutdown.service
In the empty editor insert these statements, save them and quit the editor:
[Unit]
Description=Execute script on shutdown
[Service]
RemainAfterExit=yes
ExecStop=/bin/bash -c '/bin/echo "$(/bin/date): executed this script on shutdown" >> /home/pi/shutdown.log'
# or using
#ExecStop=/full/path/to/your-script
[Install]
WantedBy=multi-user.target
Enable the new service with:
rpi ~$ sudo systemctl enable --now log-shutdown.service
After reboot you will find the file /home/pi/shutdown.log.
Ingo
  • 42,961
  • 207
Unless you are running an old version of Raspbian the concept of run levels is depreciated. The systemd equivalent to runlevel 6 would be reboot.target.
However, what you are doing should still work, except:
Those prefixes are S for start and K for kill; a script which is symlinked using the latter will have it's stop option called, if any. Stuff in runlevel 0 and 6 are mostly K because they are services started at boot that are now being shut down.
If you want to start something in reboot, use S.
