I'm working on an audio installation involving PiFM (https://github.com/oatmeal3000/pi2fm) that I want to play random audio files from a large selection of .wavs. My plan is to randomly select an audio file from this selection and then pass it to a function that will
A. Play it
B. Determine its length so that next random selection will play after the first one finishes..and so on (I expect maybe having 5 - 6 .wavs play after each other.
The below code does not include a random function as I am still figuring out the duration + setInterval. I am testing with just two audio files for now;
//this global variable
//allows me to assign
//length of audio1 track
//and use it in audioPlay();
var audio1Duration;
//A function that plays audio 1 over pifm and also gets its length using SOX
function audio1(){
// gets child_process.exec for this function
var exec = require("child_process").exec
//plays pi2fm
exec("sudo -E /home/pi/Path/To audio1wav 103.50");
// gets audio duration via soxi command
exec("soxi -D /home/pi/Path/To audio1.wav", function(err, stdout){
if (err){
throw err;
//Globla Var is assigned value of stdout * 1000
audio1Duration = stdout * 1000; //converts seconds into milliseonds for SetTimeout
console.log("This is audioDuration:" + audio1Duration);
function audio2(){
//plays pi2fm
exec("sudo -E /home/home/pi/Path/To audio2.wav 108.50");
exec("soxi -D /home/pi/Path/audio.wav", function(err, stdout){
if (err){
throw err;
If I call either of the above functions on their own they will play no problem.
audio1();
or
audio2();
However when I try and trigger them using SetTimeout to play one after the other, they will either play at the same time or start when before they are meant to.
// this function should play audio1 first
//and then play audio2 based after 'audio1Duration' amount of milliseconds'
function audioPlay(){
audio1();
setTimeout(audio2, audioDuration);
audioPlay();
Any suggestions greatly appreciated
