I have a Pi3B with multiple Oses on it that use wired( kodi, ubuntu) and wireless connections( Iot). I want to assign a static IP but not sure how to go about this.
I can assign it using the router and mac address or I can put it on the device itself
Does putting it on the device apply it to all Oses installed? Can I install it on both? Can I reserve more than one IP for the same MAC?
Kendall
  • 267
It will make more sense to setup "IP and Mac binding" on your router in your case for whatever reason you'd want to run multiple OS. The procedure varies from router to router, but all you need is the MAC address of RPi eth0 or RPi wlan0 MAC address. run ifconfig to find out the MAC address, for RPi built-in eth0 and wlan0 when your RPi is connect to the network, the mac address has a prefix of b8:27:eb:??.??.??.
No, you can't map more than 1 IP for the same MAC.
hcheung
  • 865
