I have sample app that wait on signal from IR sensor that is connected to GPIO15 and 14:
ser = serial.Serial(port="/dev/ttyAMA0",baudrate=115200, timeout=1)
io.add_event_detect(15,io.RISING, callback=inputLow, bouncetime=200)
def inputLow(channel):
  print('signal test')
And now I want to run screen: screen /dev/ttyAMA0 115200
  • 1) I can only run screen because when I run above application I get error device ttyAMA0 is busy
  • 2) when I run only gnu screen in terminal I see only black screen, when I send signal to IR sensor on the terminal nothing happens, screen is black
How can I read data from ttyAMA0?
user79083
There is ABSOLUTELY NO REASON to use /dev/ttyAMA0 in a moderately up-to-date OS. This is connected to Bluetooth (by default) on Pi3 and PiZeroW.
In ALL models use /dev/serial0 which is the default serial port (if enabled), even if ports are swapped.
See How-do-i-make-serial-work-on-the-raspberry-pi3
