HW: Raspberry Pi 3, 16 gig hard drive
Relevant Output:
Starting dhcpcd on all interfaces...
Starting LSB: Autogenerate and use a swap file
Starting LSB: Switch to ondemand cpu governor(unless shift key is pressed)..
reset
Description
If I don't press shift on time my Raspberry Pi constantly resets itself. I used the Raspbian configured openhabian ISO image but my understanding is that this issue is part of Raspbian boot. SSH connection is not possible.
Otherwise image works fine.
Aurora0001
  • 6,357
  • 25
  • 39
Thomas
  • 151
My raspberry pi has also suddenly starting going into a restart loop due to this.
I'm not sure why switching to the ondemand cpu governor causes a problem, but I've disabled it for now following instructions in this post: How to change the default governor?
You can do this by disabling the raspi-config service which, for me, didn't do anything other than switch to the ondemand cpu governor. Here's how:
sudo systemctl disable raspi-config
MetaFight
  • 103
