I am using PIGPIO library to read temperature and humidity from a DHT22 sensor. This is the script I am using.
import os
import sys
import time
import pigpio
pi = pigpio.pi()
import DHT22
s = DHT22.sensor(pi,4,17)
s.trigger()
time.sleep(0.2)
print("{} {} {:3.2f} {} {} {} {}".format(
    s.humidity(), s.temperature(), s.staleness(),
    s.bad_checksum(), s.short_message(), s.missing_message(),
    s.sensor_resets()))
s.cancel()
pi.stop()
the script runs well and return the temperature and humidity as expected. However, in my terminal I got the following error:
Error in atexit._run_exitfuncs:
  File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
    func(*targs, **kargs)
  File "/home/pi/share/dht_py/pigpio_dht22/DHT22.py", line 238, in cancel
    self.pi.set_watchdog(self.gpio, 0)
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 1764, in set_watchdog
    self.sl, _PI_CMD_WDOG, user_gpio, int(wdog_timeout)))
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 983, in _pigpio_command
    sl.s.send(struct.pack('IIII', cmd, p1, p2, 0))
AttributeError: 'NoneType' object has no attribute 'send'
Error in sys.exitfunc:
What is the cause of this error and how to avoid that? Thank you in advance.
Leonard AB
  • 121
Odd. It looks like the connection to the Pi has been terminated by the pi.stop() before s.cancel() has completed all it needed to do in the background.
I'd try adding a time.sleep(0.2) after the s.cancel() to see if that gets around the problem.
joan
  • 71,852
  • 76
  • 108
