Some introduction to my case: I have an ADC (MCP3008) connected to my RasPi with SPI. To that ADC I have connected 2 multiplexers (4051 dip-chips, I plan on connecting 8 multiplexers eventually). So in total I can now connect 64 analog inputs to my raspberry pi, which is because I'm building an electric/digital xylophone.
To measure the delay between two readings of the same input I have the following code:
import Adafruit_GPIO.SPI as SPI
import Adafruit_MCP3008
import RPi.GPIO as GPIO
from time import time
MUX_0 = 26
MUX_1 = 21
MUX_2 = 20
GPIO.setmode(GPIO.BCM)
GPIO.setup(26, GPIO.OUT)
GPIO.setup(21, GPIO.OUT)
GPIO.setup(20, GPIO.OUT)
SPI_PORT = 0
SPI_DEVICE = 0
adc = Adafruit_MCP3008.MCP3008(spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE))
def readInput(i):
GPIO.output(MUX_0, i%8-1%2)
GPIO.output(MUX_1, (i%8-1>>1)%2)
GPIO.output(MUX_2, (i%8-1>>2)%2)
return adc.read_adc(i//8)
while True:
start_time = time()
for i in range(64):
adc_in = readInput(i)
if i == 63:
print(str((time() - start_time) * 1000.0) + " milliseconds")
print("Read value: " + str(adc_in))
start_time = time()
So this (for what I know) measures the time between two readings of input 9. This gives me an average delay of about 1.2ms, which is good. However, if I change the if-statement to if i == 63: for example, the average is about 7ms. I tried some other numbers and the delay seems to go up with the input numbers. However, that doesn't make sense to me and I don't know what causes it.
Below is a piece of output with if i == 0.
0.138998031616 milliseconds
Read value: 389
0.15115737915 milliseconds
Read value: 394
Read value: 392
0.136852264404 milliseconds
Read value: 391
0.149965286255 milliseconds
Read value: 395
0.142097473145 milliseconds
Read value: 389
0.140905380249 milliseconds
Read value: 393
0.139951705933 milliseconds
Read value: 392
0.1380443573 milliseconds
Read value: 390
Read value: 394
Read value: 389
0.137090682983 milliseconds
Read value: 392
Read value: 392
0.137805938721 milliseconds
Read value: 389
0.135898590088 milliseconds
Read value: 394
Below is a piece of output with if i == 63.
7.63201713562 milliseconds
Read value: 4
7.57384300232 milliseconds
Read value: 4
7.52806663513 milliseconds
Read value: 4
7.58504867554 milliseconds
Read value: 4
7.65609741211 milliseconds
Read value: 4
7.57813453674 milliseconds
Read value: 4
7.69996643066 milliseconds
Read value: 4
7.60006904602 milliseconds
Read value: 4
7.68804550171 milliseconds
Read value: 4
7.59100914001 milliseconds
Read value: 4
7.66706466675 milliseconds
Read value: 4
7.6060295105 milliseconds
Read value: 4
7.5900554657 milliseconds
Read value: 4
Edit:
I just continued testing to find out if it's the adc or python that makes the difference. So I replaced the range in the for-loop with range(63, -1, -1), effectively reading the inputs in reverse order. For some reason, the numbers are now reversed as well. I.e. the very low delay is now with input 63 and the high delay with input 0. Still no clue why this is though.
Edit 2: Added output excerpts for clarification.
