11
I have a very noob problem with my Raspberry Pi 3b (all updated to latest stable version available). I want to use it to automate some scripts I've written in R that run smoothly on my Win10 machine under R 3.4.3 within RStudio. As I move to the command line of the RPi, I get an error concerning certificates when R tries to download some file from the philadelphiafed.org website. This error reads
Error in download.file("https://www.philadelphiafed.org/-/media/research-and-data/real-time-center/greenbook-data/documentation/gbweb_row_format.xls?la=en",  : cannot download all files
Calls: source -> withVisible -> eval -> eval -> download.file
In addition: Warning message:
In download.file("https://www.philadelphiafed.org/-/media/research-and-data/real-time-center/greenbook-data/documentation/gbweb_row_format.xls?la=en",  : URL 'https://www.philadelphiafed.org/-/media/research-and-data/real-time-center/greenbook-data/documentation/gbweb_row_format.xls?la=en':
status was 'Peer certificate cannot be authenticated with given CA certificates'
Given that the problem concerns CA certificates, I verified those that the Philly Fed site uses, it turns out I need to install the Entrusted L1K certificate I found here so to solve this issue. The noob question is then how do I install these certificates and tell the RPi to include them in its library? Any help is much appreciated!
Ceschi
CA certificates are located in /etc/ssl/certs as well as /usr/share/ca-certificates/ and in some cases /usr/local/share/certificates.
In general CA certs should not be manually added to the local trust store. There are reasons why certain CAs are not included. Without further research, it's unclear why this particular CA root cert was not included in Raspbian. It seems to be included in my Debian 'Buster' installation running Brave Browser.
All trusted CA certificates are added to a main trust store at etc/ssl/certs/ca-certificates.crt. The main trust store is updated through either through:
update-ca-certificates
or reconfiguring the ca-certificates package using:
dpkg-reconfigure ca-certificates
Procedure to add CA Certificates Manually
It's been awhile since I manually updated CA certs on a client machine. The following procedure worked on my Raspberry Pi running Raspbian Stretch:
Create a local cert directory:
mkdir /usr/share/ca-certificates/local
Download the CA cert:
cd /usr/share/ca-certificates/local
wget https://entrust.com/root-certificates/entrust_l1k.cer
Reformat the certificate into PEM:
openssl x509 -inform PEM  -in entrust_l1k.cer -outform PEM -out entrust_l1k.crt
Reconfigure the ca-certificates package:
When prompted for what do to with new certificates, choose ask. And then select the entrust_l1k.crt with space.
Test that it works:
lynx https://www.philadelphiafed.org
And/or:
openssl s_client -connect www.philadelphiafed.org:443
The result of the working procedure is a logical link in /etc/ssl/certs to the certificate in /usr/share/ca-certificates/local and the new certificate being added to the trust store.
Hopefully, this tested procedure works for you.
RubberStamp
  • 1,449
In Raspbian GNU/Linux 9.4 (stretch) your local CA certificates should be placed in /usr/local/share/ca-certificates to be added to /etc/ssl/certs/ca-certificates.crt. These should have a .crt extension. see man update-ca-certificates
hfmanson
  • 151
