As stated in Why is my Audio (Sound) Output not working?, to initialise the sound driver, you must run sudo modprobe snd_bcm2835 every time you want to output sound.
How do I get this to run on boot? (i.e. before logging in and without any input)
Loading modules at boot is a little different to running startup commands.
Add the module name as a new line in /etc/modules
Add the module name to the module array in /etc/rc.conf, the line should look like this:
modules=(snd_bcm2835)
Or for the new systemd configuration:
echo "snd_bcm2835" | sudo tee -a /etc/modules-load.d/snd_bcm2835.conf
To answer the specific question about sudo modprobe snd_bcm2835, add the module to /etc/modules and reboot. (You will need to be root to do this.)
Debian using initscripts to initialise the system, and you can use them to run arbitrary commands. You need to install a script similar to the following in /etc/init.d.
#! /bin/sh
# /etc/init.d/blah
# Some things that run always
touch /var/lock/blah
# Carry out specific functions when asked to by the system
case "$1" in
start)
echo "Starting script blah "
echo "Could do more here"
stop)
echo "Stopping script blah"
echo "Usage: /etc/init.d/blah {start|stop}"
exit 1
esac
exit 0
You should ensure it is runnable and owned by root.
sudo chmod 755 /etc/init.d/blah
sudo chown root:root /etc/init.d/blah
Then you need to register it to run at startup.
sudo update-rc.d blah defaults
There are loads of ways of running a command at start-up in Linux but my favoured approach is to create an initialisation script in /etc/init.d and register it using update-rc.d. This way the application is started and stopped automatically when the system boots / shutdowns.
See this post for a set of instructions on how to create one on the Raspberry Pi.
My preferred approach would be to add the setup command to /etc/rc.local where it would be initialised at the end of boot, before you are asked to login.
