Does anyone know if this Kuman 7" TFT LCD Capacitive Touch Screen is compatible with the Raspberry Pi Zero? On the website it says Raspberry Pi 3 2 Model B, RPi 1 B+ A but why wouldn't it work with the Zero?
It's working with my zero. However you will need to adjust the settings to use the entire screen, just researching that now.
The Kuman screen (which should come with the proper cable) is: Kuman Capacitive 7" inch Touch Screen TFT LCD module HDMI 800x480 for Raspberry Pi 2 and RPi 1 Model B B+ BB BLACK SC7B
This page helped: 7-Inch-800x480 Display Kit(without Touch Screen) SKU:Z-0111
The touch screen works on the latest Raspbian (19?)
- 864 x 480 x 24bit graphics content through SSD1963 controller
and my RPi settings in /boot/config.txt
hdmi_group=2
hdmi_mode=14
or for exact screen dimensions (tested and working).
hdmi_group=2
hdmi_mode=87
hdmi_cvt=800 480 60
See Video options in config.txt
The LCD should come with the adapter (mine did, ordered off amazon from Kuman), but yes, as the Raspberry Pi Zero is mini HDMI and the Kuman LCD is regular HDMI, you need an adapter... However it does not just work. On boot up you will find Raspbian running in 4:3 when it should be 16:9 and the touch will be off. The settings above will get it working correctly on boot.
Update
I found the cd that came with the lcd. The config.txt lists these settings for the LCD.
max_usb_current=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
- 41
- 5
The screen itself looks like it work just fine. However, the neither the HDMI cable nor the USB cable that accompany the unit will work with Pi Zero.
- 1,449
- 1
- 12
- 16
