I'm trying to use the module 'smbus' on python3. I've downloaded it - when I try to download smbus, it says that smbus is up to date and installed. However, when I try to use it, it says the module is not found. I've found a similar problem with pip3. It's downloaded but pip is an unrecognized command. Thank you!
EDIT 1: I think this is because of a mix up of Python 2/3
EDIT 2: when I run apt-cache search smbus, I get:
pi@raspberrypi ~ $ apt-cache search smbus
python-smbus - Python bindings for Linux SMBus access through i2c-dev
pypy-smbus-cffi - This Python module allows SMBus access through the I2C /dev
python3-smbus - Python 3 bindings for Linux SMBus access through i2c-dev
EDIT 3: I downloaded smbus by:
sudo apt-get update
sudo apt-get install -y python3-smbus
MatsK
  • 2,882
  • 22
Issac Jacob
Sounds like you are only downloading modules and not installing them. Here's how to do it.
  1. Installing pip: sudo apt-get install python-pip python3-pip
  2. Installing smbus: sudo apt-get install python-smbus python3-smbus python-dev python3-dev
tlhIngan
  • 3,372
  • 33
