My Raspberry Pi doesn't boot. I reisntalled Raspbian as I did the last time, when it worked correctly, and still it doesn't boot.
I was working with the GPIO when the display turned off, and after that I can't boot anymore. Also, it's not a issue of the power supply, as it worked fine, and still works when I connect it to my cellphone. The PWR and ACT LEDs are on during the first 1.5 minutes.
Anyone knows why can my Raspberry Pi won't boot?
Renan
  • 129
Gabriel Esteban
  • 175
While working on GPIO you might have made a shortcut, causing protection fuse to blow up. It is reported that these fuses may need several hours or even few days to fully recover. So it is possible that your RaspberryPi will boot just fine if you leave it for couple days. Be sure to checkout troubleshooting guilde if it's not.
Krzysztof Adamski
  • 9,605
  • 38
  • 53
most probably you've burned your Raspi during your GPIO experiments. should have ordered two, then you always have a way to compare and check where the problem is.
on the other hand, getting new SD card is cheaper, and you may want to start from creating another SD card. then try to prove it works -- ask a friend to boot from your newly created SD card or ask someone who has Raspi and is willing to help, maybe send it to another city and back. if you still cannot boot with a proven to work SD card, then it's really a time for a replacement.
also, you might try to analyze your LED status using this guide.
lenik
  • 11,533
  • 37
I recommend you get one of these serial dongles off ebay for a couple of dollars (at least for next time).
If nothing is showing up there, you've probably damaged the chip.
Consider @Krzysztof Adamski's answer. You can temporarily solder a wire across the main polyfuse if you don't want to wait a couple of days to confirm whether it's dead.
John La Rooy
  • 12,005
  • 48
  • 77
Using a multimeter, test the F3 Polyfuse following these instructions.
Dvid
  • 77
