15
I just installed a clean image of the latest Raspbian Stretch Lite.
Specifically - 2017-09-07-raspbian-stretch-lite.img
ifconfig shows that my wifi interface wlan0 is detected and up.
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:c6:dc:d4  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 2516  bytes 144456 (141.0 KiB)
        TX packets 2516  bytes 144456 (141.0 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.165  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::d4dd:c202:d337:c0de  prefixlen 64  scopeid 0x20<link>
        ether 00:24:a5:36:ed:49  txqueuelen 1000  (Ethernet)
        RX packets 49461  bytes 49499638 (47.2 MiB)
        TX packets 36499  bytes 4455517 (4.2 MiB)
However, trying to use the ifdown or ifup commands says that the device does not exist.
[pi:~] sudo ifdown wlan0
ifdown: unknown interface wlan0
Perhaps, ifup and ifdown will only work if /etc/network/interfaces is used to manage the networking devices, and that is apparently not the case in the raspbian stretch lite version dated 2017-09-07
saraf
  • 571
What does work instead of
sudo ifup wlan0
sudo ifdown wlan0
is
sudo ifconfig wlan0 up
sudo ifconfig wlan0 down
saraf
  • 571
I had a similar problem after installing PiHole. I found this site to be helpful. https://raspberry-projects.com/pi/programming-in-c/tcpip/configuring-network-adaptors
In my case, I had tried to change the PiHole static IP after instalation and I had two IPs in the /etc/dhcpcd.conf file. Once I corrected the error my Pi is working on the wired connection again.
