9
I have made a new Raspbian installation. All good. I wanted to delete pi user and make another user with same privileges (lets say gordon).
So first I enabled direct ssh access to user root by doing this:
   sudo nano /etc/ssh/sshd_config
...and editing the line
  #PermitRootLogin prohibit-password
to
   PermitRootLogin yes
Then I restarted and directly login as root.
So I followed https://gordonlesti.com/change-default-users-on-raspberry-pi/ recommendations.
I added a step to make new user gordon belong to the same exact groups pi belongs. So I did this to know those groups...
  root@raspberrypi:~# groups pi
  pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
... and then this to make new user belong to them.
  root@raspberrypi:~# usermod -a -G adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,input,netdev,spi,i2c,gpio gordon
I also did a change in /etc/lightdm/lightdm.conf at line
    autologin-user=pi
that I changed to
    autologin-user=gordon
All good til I get to "Delete pi" step in the guide.
I get this error:
 deluser pi
 Removing user `pi' ...
 Warning: group `pi' has no more members.
 userdel: user pi is currently used by process 445
 /usr/sbin/deluser: `/usr/sbin/userdel pi' returned error code 8. Exiting.
So I did a
  ps -aux| grep 445
and I got
   pi  445  0.0  0.6  9768  5944  ?  Ss  13:28  0:00  /lib/systemd/systemd --user
So I have several questions.
  • How to know what is that process?
  • Supposing my new user name is gordon ..... how can I make this process not run as pi anymore and run as gordon ?
Thanks !!
FedeKrum
  • 193
I think I tracked it down for you...
You removed the lightdm autologin for user pi ... but, if you are using noobs, there is another autologin here:
/etc/systemd/system/autologin@.service
line 28:
ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM
So, it seems that noobs is has two locations for autologin with the user pi
Remove the second one, and see what happens.
RubberStamp
  • 1,449
I did what rubberstamp did, but it still did noy work.
So I went to preferences, raspberry pi configuration and removed the check from auto login. Then it worked for me.
Ghanima
  • 15,958
  • 65
Burd
Rename both files and terminal autologins will not occur on the next reboot. A reboot is required or autologin will continue to relogin anytime these terminals exits.
sudo mv /etc/systemd/system/autologin@.service /etc/systemd/system/autologin@.service.bak
sudo mv /etc/systemd/system/getty@tty1.service.d/autologin.conf /etc/systemd/system/getty@tty1.service.d/autologin.conf.bak
For lightdm, I comment out the autologin line with:
sudo sed -i.bak 's/^autologin-user=pi/#autologin-user=pi/g;' /etc/lightdm/lightdm.conf
