I'm doing some experiments with openHAB2 on my Raspberry Pi 3 (with Raspbian installed).
At the moment I've connected a LED to GPIO pin #2 and I'm able to turn it on/off from openHAB2.
The problem is that when I shutdown my Raspberry, the LED linked to GPIO pin #2 remains active.
I've read this link from OpenHAB official documentation about GPIO binding and seems that I have to unexport GPIO pin editing the body of the do_stop() function on openHAB init.d script.
I've done two attempts:
1) I've edited the do_stop() function that way (copy-paste from openHAB documentation about GPIO):
do_stop()
   start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile
   $PIDFILE $
   #unexport all gpio's
   echo 2 > /sys/class/gpio/unexport
   RETVAL="$?"
   [ "$RETVAL" = 2 ] && return 2
   # Wait for children to finish too if this is a daemon that forks
   # and if the daemon is only ever run from this initscript.
   # If the above conditions are not satisfied then add some other code
   # that waits for the process to drop all resources that could be
   # needed by services started subsequently.  A last resort is to
   # sleep for some time.
   start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec
   $DAEMON
   [ "$?" = 2 ] && return 2
   # Many daemons don't delete their pidfiles when they exit.
   rm -f $PIDFILE
   return "$RETVAL"
2) I've edited the default init.d script adding only the line about unexporting GPIO pin #2:
do_stop() {
  log_daemon_msg "Stopping $DESC" "$NAME"
  echo "2" > /sys/class/gpio/unexport
  if /usr/share/openhab2/runtime/bin/stop
  then
    # workaround stop returns before the openhab process has really stopped
    timeout=0
    if stpid=`cat /var/run/openhab2.pid 2> /dev/null`; then
      killwaitpid $stpid
    fi
    rm -f $PIDFILE
    # In case the pid in the pidfile was wrong, also kill/stop existing process
    killwaitpid $EXISTINGPID
    log_end_msg 0
    return 0
  else
    log_end_msg 1
    return 1
  fi
Both solutions don't work and the LED turns ON after Raspberry was turned off, even if I turn my Raspberry off with the LED OFF; where is the mistake?
Roberto Milani
  • 127
If you are using BCM2 (physical pin 3), this has a 1.8kΩ pullup resistor. This is intended for use as I²C SDA, and the state of the pin will be HIGH, even if set as INPUT, unless you deliberately pull it low.
In general pin 3, 5 should not be used for GPIO, unless you make allowance for the pullup.
There are 7 pins with pullup, although most use the internal pullup, and are easily over-ridden, but can still activate external circuits - see http://www.panu.it/raspberry/
Roberto Milani
  • 127
