I'm trying to get u-boot working on Raspberry Pi 3 but so far no success. Every time I plug in my SD card to the Pi there isn't any output to the console, only the green LED blinks several times. Currently I'm trying to build u-boot this way:
git clone git://git.denx.de/u-boot.git
sudo apt-get install gcc-aarch64-linux-gnu
export CROSS_COMPILE=aarch64-linux-gnu-
make rpi_3_defconfig
make -j8 -s
No errors during building, and here is what I have on my SD card:
bcm2709-rpi-2-b.dtb
bcm2710-rpi-3-b.dtb
bcm2710-rpi-cm3.dtb
bootcode.bin
cmdline.txt
config.txt
fixup.dat
kernel7.img
overlays
start.elf
u-boot.bin
In the config.txt I wrote kernel=u-boot.bin
I built the kernel itself with buidroot but I think the buildroot settings don't matter since I didn't even get output from u-boot.
The kernel7.img loads just fine.
I've already tried several ways to build u-boot (using different compilers like arm-bcm2708-linux-gnueabi- etc., I tried to build u-boot with help of buildroot) but no luck. Every time I turn on my RPi3 the green led blinks several times and nothing shows up in the console. Please, help me with some solid way to build u-boot and make it work on RPi3.
Aurora0001
  • 6,357
  • 25
  • 39
Make sure you have the below entries in the config.txt for arm64 support :
arm_64bit=1
device_tree_address=0x100
device_tree_end=0x8000
Optionally, add 'enable_uart=1' if you need serial console support.
If needed add boot.scr.uimg to the boot partition to load the kernel from u-boot (u-boot looks for this file unless you disabled auto-boot while building it) :
Prepare boot_script.txt :
fdt addr 100
fatload mmc 0:1 ${kernel_addr_r} kernel7.img
booti ${kernel_addr_r} - ${fdt_addr_r}
Then run :
mkimage -A arm -O linux -T script -C none -n boot_script -d boot_script.txt boot.scr.uimg
ReddyVeeru
  • 46
Try removing device tree overlays from config.txt, if you have any.
I experienced the same problem with certain overlays that seem to have overflowed or otherwise corrupted the memory allocated for the DT in U-Boot when applied by the factory bootloader. Then I could resize the DT in U-Boot and apply those overlays that otherwise failed.
fdt addr ${fdt_addr};
fdt resize 1024;
fatload mmc 0:1 ${fdt_addr_r} overlays/pi3-disable-bt.dtbo;
fdt apply ${fdt_addr_r};
