Sorry if any of this comes across as uninformed etc, I'm normally on stack for code at work but I have a pi at home which I've only used for media up till now.
I'm trying to put RetroPie on it as I've bought some USB controllers. I have tried to copy the image file over but I apparently don't have enough space.
I've removed Wolfram & LibreOffice as I wasn't using these and I've seen from my searching these are 2 common things you can do to save space.
I've noticed that on the terminal if I do df -h I get quite a few entries starting with /dev/mmcblk0p with numbers on the end (5, then 8 through to 14). What are these and do I need them all? A lot of them are pretty large and it seems like a big win if I don't... However if I do, then what sort of things can I do to save some more space?
*furthermore: I seem to have Raspbian, OpenELEC_RP2, LibreELEC_RP2 & OSMC_PI2 at boot. I only seem to use Raspbian & OpenELEC so am I good to ditch the other 2 (guide on how would be useful too)?
I've read my initial question might be something to do with NOOBS but that makes no sense to me apart from me feeling like a complete and utter noob...
Thanks
Tim Edwards
  • 101
They are device nodes; mmcblk0 represents the SD card and p[N] the partitions on the card. It is weird you have 14 of them; this is probably because of NOOBS.
No, device nodes have a size of 0. This is because they are not actually stored files, they are interfaces to the kernel. Linux uses this strategy for a lot of things, e.g., what's mounted on /proc and /sys (and /dev) are special in memory filesystems only. However, since they are part of the kernel they do not occupy userspace RAM.
Which brings up an important point: You do not want to copy anything in those directories. If you examine the card when the system is not running, you will notice they are (or should be) empty.
You might have a read through this, which is about creating backups, for more about what should and should not be in a Pi filesystem image.
It also explains how to copy the contents of the filesystem rather than the whole thing as a blob, which may address this problem:
The image will be the size of the filesystem, which if it is 4 GB, will be 4 GB even if the filesystem is 99% empty.
