I need help changing my IP to dynamic or confirming that my is IP to dynamic because I may have set it to static when I installed PiVPN.
/etc/network/interfaces is basically empty
Human
  • 1,208
  • 35
$ sudo raspi-config
  • Select 'Network Options'
  • Select 'WiFi'
  • Enter SSID
  • Enter SSID passphrase
lloyd
This command is to confirm you real IP address. If the IP changed in period of time, normally, it is regarded as not static IP.
curl -s http://ipv4.icanhazip.com
You mention you use a VPN service. If the VPN successfully run up, you are able to use the above command to check the IP address.
jefferyear
  • 193
