I'm trying to configure port knocking on my RasPI running Raspbmc, using knockd.
Here's what I've done:
sudo apt-get update
sudo apt-get install knockd
...then edited the files:
/etc/default/knockd :
# PLEASE EDIT /etc/knockd.conf BEFORE ENABLING
START_KNOCKD=1
/etc/knockd.conf:
[options]
logfile = /var/log/knockd.log
[open_close-PPTP_VPN]
sequence = 3141,5926,5359
seq_timeout = 10
tcpflags = syn,ack
start_command = /sbin/iptables -I INPUT -s %IP% -p tcp --dport 1723 -j ACCEPT
cmd_timeout = 45
stop_command = /sbin/iptables -D INPUT -s %IP% -p tcp --dport 1723 -j ACCEPT
then start the daemon:
sudo service knockd restart
Check it's up:
ps aux |grep knoc
root 12560 0.0 1.1 6028 4424 ? Ss 02:55 0:00 /usr/sbin/knockd -d
pi 12877 0.0 0.1 1972 612 pts/1 S+ 02:57 0:00 grep knoc
Capture packets to see what's happening on the wire.
sudo tcpdump 'src 211.212.77.33 and portrange 3000-6000 and tcp' -nn
Now test (from an Android Phone, using 3G data and app Port Knocker) - here's the output (192.168.1.31 is the IP of RasPi).
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
02:56:15.244087 IP 211.212.77.33.55399 > 192.168.1.31.3141: Flags [S], seq 3126604301, win 14600, options [mss 1460,sackOK,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,wscale 3], length 0
02:56:15.528594 IP 211.212.77.33.55405 > 192.168.1.31.5926: Flags [S], seq 2477232254, win 14600, options [mss 1460,sackOK,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,wscale 3], length 0
02:56:15.824344 IP 211.212.77.33.55408 > 192.168.1.31.5359: Flags [S], seq 154955077, win 14600, options [mss 1460,sackOK,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,nop,wscale 3], length 0
Nice and dandy, 3 TCP packets, each about 300 ms apart, on the correct ports.
... but watch iptables -L -n shows no changes in the iptables config.
Also, there's nothing in the knockd log file except the 'server started message'.
It appears the knockd server either doesn't receive the packets, or fails to recognize them...
I even tried the 'start command' touch /tmp/knock.txt but of course, the file failed to make an appearance.
Any suggestions?
