I've installed the GPIO python library to read/write to GPIO pins. To get the state of the pins I'm using "gpio readall" which displays a table with all the pins from the RPI and I can see which pin is HIGH and which one is LOW.
The problem i'm facing is that if I connect a ribbon cable to RPI (the other end of the cable is not connected) and run the "gpio readall" command multiple times one after another I see different values for the pins... the values are randomly changing... but if I remove the ribbon cable and run the same command multiple times I get all the time the same result...
I'm expecting to see the same values with or without the ribbon cable connected...
Do you have any idea why is that ?
