I'm a newbie to Raspberry Pi's, but one of the things I was thinking about doing is running it off batteries (I see many people do this) - that led me to concerns about shutting down gracefully. Is there a software only solution that would allow me to detect input voltage?
Asked
Active
Viewed 2.4k times
12
vcgencmd will show the internal voltages for core, sdram_c, sdram_i, and sdram_p:
vcgencmd measure_volts core
The output will look something like this:
volt=1.20V
The following shell commands will display all the voltages:
for id in core sdram_c sdram_i sdram_p
do
echo -e "$id:\t$(vcgencmd measure_volts $id)"
done
Gregology
- 229
- 2
- 6
10
you'll need some external circuitry to do that, because afaik the raspberry does not provide the battery voltage anywhere in the system: http://raspi.tv/tag/raspberry-pi-monitoring-its-own-battery-voltage
lenik
- 11,533
- 2
- 32
- 37
