I know that cron events are stored in /var/log/syslog and I can use a command like:
sudo cat /var/log/syslog | grep cron
to see them.
I'd much rather have the system keep a separate cron log file so it doesn't do as much work watching it, as it sorts through all the syslog messages to pull out the cron notifications.
Then I want to use the watch command so I always have an open terminal window showing cron activity.
How do I make the system keep a separate /var/log/cron.log file?
SDsolar
  • 2,378
  • 26
  • 43
Make a change in /etc/rsyslog.conf with your favorite editor:
sudo vi /etc/rsyslog/50-default.conf
Find the line that says
#cron.*         /var/log/cron.log
Remove the # from that line. Then restart the service:
sudo service rsyslog restart
From then on, all cron-related output will go to /etc/log/cron.log
Then to watch it in a terminal window,
create a wcron command script:
echo "#!/bin/bash" >wcron
echo "watch -n 120 tail -n25 /etc/log/cron" >>wcron
chmod +x wcron
sudo cp wcron /usr/sbin
From then on, whenever you want to monitor cron in real-time, enter:
wcron
SDsolar
  • 2,378
  • 26
  • 43
