-3
Given: So, I have an 8 GB sd card.
TODO: Get raspbian
Solution:
First I delete the partition:
Command (m for help): d
Selected partition 1
Partition 1 has been deleted.
After i've created a new partition:
Command (m for help): n
Partition type
  p   primary (0 primary, 0 extended, 4 free)
  e   extended (container for logical partitions)
Select (default p): p
Partition number (1-4, default 1):
First sector (2048-15130623, default 2048):
Last sector, +sectors or +size{K,M,G,T,P} (2048-15130623, default 15130623):
Created a new partition 1 of type 'Linux' and of size 7.2 GiB.
This is how it looks:
Command (m for help): p
Disk /dev/sdb: 7.2 GiB, 7746879488 bytes, 15130624 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xa208ea74
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1        2048 15130623 15128576  7.2G 83 Linux
Setting table:
Command (m for help): t
Hex code (type L to list all codes): b
If you have created or modified any DOS 6.x partitions, please see the fdisk documentation for additional information.
Changed type of partition 'Linux' to 'W95 FAT32'.
Saving Changes
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Making it bootable:
Command (m for help): a
The bootable flag on partition 1 is enabled now.
print:
Disklabel type: dos
/dev/sdb1  *     2048 15130623 15128576  7.2G  b W95 FAT32
Saving changes
Syncing disks.
Formating:
Wed Oct 18; 23:57:49; marton;/backup/desktop/programs/images ;  $  sudo mkfs -t vfat /dev/sdb1
mkfs.fat 3.0.26 (2014-03-07)
After that I just burned the image:
Wed Oct 18; 23:58:27; marton;/backup/desktop/programs/images ;  $  sudo dd bs=4M if=2017-09-07-raspbian-stretch-lite.img of=/
dev/sdb1 conv=fsync
442+1 records in
442+1 records out
1854590976 bytes (1.9 GB) copied, 461.441 s, 4.0 MB/s
After that the image was visible and mountable, but now when I plug it in :
Thu Oct 19; 09:50:11; marton;/backup/desktop/programs/images ;  $  mount /dev/sdb
mount: can't find /dev/sdb in /etc/fstab
Thu Oct 19; 09:51:30; marton;/backup/desktop/programs/images ;  $  mount /dev/sdb1
mount: can't find /dev/sdb1 in /etc/fstab
QUESTION: WHY IS IT NOT MOUNTABLE ?
Helpful info:
Thu Oct 19; 10:04:53; marton;/backup/desktop/programs/images ;  $  df
Filesystem     1K-blocks      Used Available Use% Mounted on
devtmpfs         1958676         0   1958676   0% /dev
tmpfs            1965996     26480   1939516   2% /dev/shm
tmpfs            1965996      2112   1963884   1% /run
tmpfs            1965996         0   1965996   0% /sys/fs/cgroup
/dev/sda7       40009728  38632340    238892 100% /
/dev/sda7       40009728  38632340    238892 100% /.snapshots
/dev/sda4         166724      4624    162100   3% /boot/efi
/dev/sda7       40009728  38632340    238892 100% /usr/local
/dev/sda7       40009728  38632340    238892 100% /var/spool
/dev/sda7       40009728  38632340    238892 100% /var/lib/mysql
/dev/sda7       40009728  38632340    238892 100% /tmp
/dev/sda7       40009728  38632340    238892 100% /var/opt
/dev/sda7       40009728  38632340    238892 100% /var/lib/pgsql
/dev/sda7       40009728  38632340    238892 100% /var/crash
/dev/sda7       40009728  38632340    238892 100% /var/lib/mariadb
/dev/sda7       40009728  38632340    238892 100% /var/lib/named
/dev/sda7       40009728  38632340    238892 100% /var/lib/mailman
/dev/sda7       40009728  38632340    238892 100% /var/lib/libvirt/images
/dev/sda7       40009728  38632340    238892 100% /var/tmp
/dev/sda7       40009728  38632340    238892 100% /var/log
/dev/sda7       40009728  38632340    238892 100% /srv
/dev/sda7       40009728  38632340    238892 100% /opt
/dev/sda7       40009728  38632340    238892 100% /boot/grub2/x86_64-efi
/dev/sda7       40009728  38632340    238892 100% /boot/grub2/i386-pc
/dev/sda1      314428412 134355888 180072524  43% /backup
/dev/sda8       59510384  14210312  45300072  24% /home
Thu Oct 19; 10:05:29; marton;/backup/desktop/programs/images ;  $  mount | grep media
Thu Oct 19; 10:06:09; marton;/backup/desktop/programs/images ;  $
Hartun
Because the Raspbian image is not a filesystem image, it's a device image. It is intended to be used like this:
dd bs=4M if=2017-09-07-raspbian-stretch-lite.img \
   of=/dev/sdb conv=fsync
Note, not sdb1 (a partition, into which you could usefully copy a filesystem), but a block device node. Admittedly, a partition device node can also be considered a block device (because it is random access), but hopefully the point is clear.
When you write the Raspbian image to a device, it will overwrite everything, so there is no point in preformatting the card. When it is done, there will be two partitions (and an MBR, so it is bootable), but those all come from the image.
Note that you can create the card by formatting it with partitions and then copying stuff in from the partitions in the image, but to do that you need to either mount the image, or else do some math based on fdisk -l raspbian.img and copy over the partitions (in which case you don't have to format them, just create the partition table). However, there is not much point to that.
