34
There is a driver project established to run Kinect on Linux. See here: https://github.com/OpenKinect/libfreenect
Will this work with an RPi? What are the constraints/obstacles likely to be?
I'm thinking this would be a real help for an ambitious robotics project, eg, setup an RPi as an onboard controller, with the Kinect as the "eyes" for object avoidance etc (or more).
Jon Egerton
  • 3,083
I have just installed this library successfully in Arch Linux. I can't see any reason why it wouldn't install in any distro. It's important to note that I do not have a Kinect, so I cannot verify that the library works, only that it compiles and installs successfully.
Here are the steps I took:
Install dependencies
These packages are dependencies of the Kinect Library or the build process, and thus need installing first:
  • cmake
  • git
  • libusb
  • freeglut
  • libxmu
  • libxi
You should be able to find these using your basic package manager.
Check out the repository
git clone git://github.com/OpenKinect/libfreenect.git
cd libfreenect && git pull origin
Build the source
cmake -DCMAKE_INSTALL_PREFIX=/usr -DPROJECT_INCLUDE_INSTALL_DIR=/usr/include -DLIB_SUFFIX="" .
make
sudo make install
Set the udev rules (so that the Kinect is detected when plugged in):
sudo install -Dm644 platform/linux/udev/51-kinect.rules /etc/udev/rules.d/51-kinect.rules
Jivings
  • 22,656
  • 94
  • 140
It's possible...video
I doubt it will be very practical to see anything, but if you just used data collection/processing, it might work. Side note: the Kinect eats up a HUGE amount of RAM to run all the visual stuff. So you could run a pared back version. Good luck :)
CAP_Cadet
Kinect works on Pi after some tweaks. Here is an example.
avra
  • 1,273
