I found this code somewhere, that can execute Python scripts from PHP.
I've installed apache2 on the Pi and I'm able to access the PHP script. But when I press the HTML buttons, nothing happens! :(
When I execute the python script via SSH, it works.. so theres nothing wrong with the python scripts I think.
I'm using WebIOPi to monitor the status of the GPIO pins.
Whats the mistake?
PS: I know that this may not be a very safe approach to control the GPIO. I just wanna give it a try though :)
TIA.
<html>
<head>
<?php
if (isset($_POST['RedON']))
exec('sudo python /var/www/red_on.py');
if (isset($_POST['RedOFF']))
exec('sudo python /var/www/red_off.py');
if (isset($_POST['YellowON']))
exec('sudo python /var/www/gpio/yellow_on.py');
if (isset($_POST['YellowOFF']))
exec('sudo python /var/www/gpio/yellow_off.py');
if (isset($_POST['GreenON']))
exec('sudo python /var/www/gpio/green_on.py');
if (isset($_POST['GreenOFF']))
exec('sudo python /var/www/gpio/green_off.py');
  <title></title>
</head>
<body>
<form method="post">
  <table
 style="width: 75%; text-align: left; margin-left: auto; margin-right: auto;"
 border="0" cellpadding="2" cellspacing="2">
    <tbody>
      <tr>
        <td style="text-align: center;">Turn LED on</td>
        <td style="text-align: center;">Turn LED off</td>
  </tr>
  <tr>
    <td style="text-align: center;"><button name="RedON">Red On</button></td>
    <td style="text-align: center;"><button name="RedOFF">Red Off</button></td>
  </tr>
  <tr>
    <td style="text-align: center;"><button name="YellowON">Yellow On</button></td>
    <td style="text-align: center;"><button name="YellowOFF">Yellow Off</button></td>
  </tr>
  <tr>
    <td style="text-align: center;"><button name="GreenON">Green On</button></td>
    <td style="text-align: center;"><button name="GreenOFF">Green Off</button></td>
  </tr>
</tbody>
  </table>
</form>
</body>
</html>
Krish
  • 237
sudo python /var/www/red_on.py most probably asks for a sudo password, which is not provided anywhere, and the command fails.
you may try echo <password> | sudo -S ..., however I haven't checked if output redirect works well in the PHP exec().
lenik
  • 11,533
  • 37
The command sudo python XYZ will be execute as the apache user. You'll need to add this user to your sudoers file.
sudo echo "apache ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
Replace "apache" with your systems apache username (may be "www-data", "httpd" or "www" on some systems.)
Suggestion
Why use Apache or PHP at all? SimpleHTTPServer is extremely simple to set-up. You can have this server handle your python scripts, while running with super-user privileges.
trillian
  • 420
emcconville
  • 450
Try running the following commands
chown root:root ./script
chmod 4775 ./script
kolin
  • 950
  • 25
str8
